Flap handle grip for LS6
Old February 14th 08, 03:48 PM posted to rec.aviation.soaring
robin
Default Flap handle grip for LS6
The rubber pistol grip on the flap handle in my LS6 is pretty badly
deteriorated. The spoiler handle grip is also going down hill. DG
replied to an email that they can't help me with replacements.
The next step could be fabrication, but I thought I'd try the group
first. Is there a source for these handgrips? I noticed pictures of
the JS1 Revelation cockpit showed grips that look similar.
I have seen wooden replacement grips and I could carve some. But I
thought I'd try and mold some.
If you have any tips or techniques let me know. I don't know what
rubber product to use, but we've got a local rubber products vendor
with a large inventory.
Thanks
Robin - RF
Old February 14th 08, 04:37 PM posted to rec.aviation.soaring
Markus Graeber
Hi Robin,
The current Type Certificate Holder for the LS4 and LS6 is AMS Flight
in Slovenia:
http://www.ams-flight.si/
They might be able to help, at least officially they would be the go
to for spare parts.
Markus
Old February 14th 08, 04:47 PM posted to rec.aviation.soaring
Tim Mara
try www.mcmaster.com
they have several handle grips...cheap...or try local ski shops for old
style ski pole grips (these were used by many sailplane manufacturers in the
past)
tim
"robin" wrote in message
Thanks
Robin - RF
Old February 14th 08, 06:26 PM posted to rec.aviation.soaring
Thanks
Robin - RF
I got a spoiler grip for my LS1f last year from Pacific Aerosport. You
can google them for the web address.
Old February 14th 08, 07:10 PM posted to rec.aviation.soaring
bumper
I've made several grips using the black foam tubing that used to be used on
bicycle drop bars of the old "10-speed" variety - Wal-Mart has them.
To make the closed-end grip, insert a scrap piece of wood, cardboard etc to
almost the length of the foam tube. Apply a small amount of super glue to
the end to be closed and squeeze shut. The super glue will bond almost
instantly.
Using a belt sander or grinding wheel, shape the closed end as desired. It
helps to have something rigid in the tube while doing this and keep the end
angled in the direction of abrasive movement so it doesn't grab.
Use silicone spray to ease installation if the handle is larger than the
tubing ID.
Open lengths of this foam tubing can be used to cover the stick handle as
well. Liberal application of silicone spray allows use over existing
handles. If existing handle OD is much greater than foam tube ID, then cut
foam tubing a bit too long (1/2 to 3/4 inch extra) as foam length will
shrink a bit as foam is stretched over handle.
bumper
Minden
QV & MKII (cheapest toys you can buy for your glider)
Thanks
Robin - RF
Old February 14th 08, 07:32 PM posted to rec.aviation.soaring
robin
Thanks
Robin - RF
Thanks for the responses. I see some good ideas. I did forget to
mention in my original post that the metal handles that the grips fit
over is not a round tube like a ski pole or bicycle handlebar. Rather
they are thin metal slaps. Probably I can modify a round hole to file
the slab easier than I can manufacture an entirely new grip.
Old February 15th 08, 03:57 AM posted to rec.aviation.soaring
Sarah Anderson[_2_]
I wish I knew! My (our) LS6 flaphandle is pretty shabby too.
Let us know what you find out please.
We recently replaced our stick grip ( different a/c, a Libelle ) with
close to OEM parts... a xc ski pole grip. That would probably work with the spoiler grip,
but not the flaps.
Sarah
Thanks
Robin - RF
Old February 15th 08, 05:13 AM posted to rec.aviation.soaring
Thanks
Robin - RF
My partner replaced the flap and airbrake grips in our Kestrel which
has a flat bar as the main part also.
He simply made a couple of half rounds which he shaved down to the
shape he wanted ,one for each side of the slab, drilled 2 holes
through the
slab and half rounds and countersunk the the holes in the half rounds
and simply bolted the assembly together after checking all clearances.
After a final sand 3 coats of varnish, we had nice looking wood
handles
for our controls and we found they were easier to hold and felt
better
than plastic ones.
gary
Old February 15th 08, 10:35 PM posted to rec.aviation.soaring
meile
Hi Robin
Mr. Siegfried Piontkowsky the designer, and co constructer with Lembke,
of the LS11 produces some nice handles in carbonfiber.
He also produces winglets for the LS6a.
If you are interested I can provide you with some photes of the handles.
Best regards
Peter Meilhede
also a lucky LS6 owner:-)
Old February 16th 08, 01:19 AM posted to rec.aviation.soaring
On 15 fév, 16:35, meile wrote:
Hi Robin
Best regards
Peter Meilhede
Hi,
An email address please.
S6, LS6b owner.
Need help identifying this Grip dstory Rotorcraft 0 March 4th 07 06:58 PM
When I lower the wing flap handle why don't they? Jim Burns Piloting 11 October 17th 06 08:08 PM
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 05:54 AM
Looking for brush/trim for flap/spoiler handle slots John Soaring 2 November 27th 03 01:24 AM
RAC grip (Formerly MAC) Ed Wischmeyer Home Built 7 August 26th 03 04:44 PM
