Headsets
Old March 23rd 08, 11:20 AM posted to rec.aviation.piloting
Mike Gilmour[_2_]
Default Headsets
Do ANR and other headsets usually provide sidetone? (sidetone = a small part
of your speech is fed back to your phones). I've used some aviation
headsets with no sidetone, it's a bit like talking with your fingers in your
ears, not too good. Is aircrafts sidetone generation an intregal part of
the aircrafts intercom system? The reason I ask as once being a local radio
presenter and maritime comms I don't know of anytime where sidetone was
absent from headphones or headsets.
Old March 23rd 08, 01:18 PM posted to rec.aviation.piloting
Travis Marlatte
Default Headsets
It's not the headset. Its' the device it's plugged into. ANR or passive
makes no difference.
Travis
Lake N3094P
PWK
"Mike Gilmour" wrote in message
part of your speech is fed back to your phones). I've used some aviation
your ears, not too good. Is aircrafts sidetone generation an intregal
part of the aircrafts intercom system? The reason I ask as once being a
local radio presenter and maritime comms I don't know of anytime where
sidetone was absent from headphones or headsets.
Old March 23rd 08, 01:44 PM posted to rec.aviation.piloting
Mike Gilmour[_2_]
Default Headsets
Ok, thanks however the Lightspeed Thirty 3G has 'Personal Side-Tone EQ'
which seems to imply headset control in that case?
"Travis Marlatte" wrote in message
Travis
Lake N3094P
PWK
Old March 23rd 08, 02:10 PM posted to rec.aviation.piloting
Thomas Borchert
Default Headsets
Mike,
That's just marketing speak for it having the option of enhancing the
sound that comes into it. Makes music sound much better.
As Travis said, the sidetone comes from the intercom/radio.
Thomas Borchert (EDDH)
Old March 23rd 08, 03:10 PM posted to rec.aviation.piloting
Peter Clark
Default Headsets
On Sun, 23 Mar 2008 10:20:22 -0000, "Mike Gilmour"
I don't think the sidetone ever generates in the headset, it's a
function of the audio panel isn't it??
Old March 23rd 08, 03:20 PM posted to rec.aviation.piloting
Mike Gilmour[_2_]
Default Headsets
"Peter Clark" wrote in message
part
your
radio
It is apparently, therefore some audio panels don't provide sidetone.
Old March 23rd 08, 04:01 PM posted to rec.aviation.piloting
Andrew Sarangan
Default Headsets
On Mar 23, 9:10 am, Thomas Borchert
Mike,
But there is no inherent reason why side tone cannot be provided
within the headset. It's got a battery and an amplifier, so it would
not be a big stretch to redirect the microphone signal into the
headset.
However, when the sidetone is generated by the intercom, and you can
hear yourself speak, you can safely assume that the other party can
hear you too. That would not be the case if the side tone is generated
by the headset.
Old March 23rd 08, 04:38 PM posted to rec.aviation.piloting
Peter Clark
Default Headsets
On Sun, 23 Mar 2008 14:20:49 -0000, "Mike Gilmour"
part
your
radio
That I can attest to. Some older panels I've run into don't, or the
sidetone circuit is busted.
Old March 23rd 08, 05:00 PM posted to rec.aviation.piloting
Thomas Borchert
Default Headsets
Andrew,
by the headset.
Well, it would diminish battery life, of course.
Also, the microphone is powered by the intercom/radio through its plug.
Interestingly, the new Lightspeed Zulu has an option to power the mic
from the headset battery, since it can be used as a Bluetooth headset
for your phone and you might want to do that with aircraft power of.
Old March 24th 08, 03:37 AM posted to rec.aviation.piloting
Dave S
Default Headsets
This is not a headset issue. This is an intercom issue. And usually the
answer is yes. Most if not all modern (in the past 10-15 years) aviation
radios and intercoms have built in sidetone functionality.
Headsets tony roberts Piloting 4 September 8th 06 04:46 AM
Headsets tony roberts Owning 2 September 2nd 06 08:30 PM
about headsets Sylvain Piloting 0 August 11th 06 06:36 AM
In-Ear Headsets John Clonts Piloting 3 November 22nd 05 10:19 PM
Anyone tried any of the "in the ear" headsets? Charles General Aviation 4 August 14th 05 02:41 PM
