LX 5000 - Invalid IGC File
Old April 11th 08, 08:02 PM posted to rec.aviation.soaring
Randy[_2_]
Default LX 5000 - Invalid IGC File
Good afternoon,
I have a LX 5000 version 11.1. During my last 6 flights, I have
been getting an invalid IGC file when I download to OLC. During
the power up of the LX5000, I keep getting the following WARNING,
SECRET KEY NOT VALID! PRESS ENTER TO QUIT!
When I was in Moriarty last week, a couple members from the
ABQ Soaring Club confirm that my IGC file was corrupted.
I am using SeeYou Moble 7.2 version and download my WP and
task through my PDA.
I have email this question to LX and am waiting for an answer.
Does anyone have a solution to this question?
Thanks for your time!
Randy Teel
N304RS
Old April 11th 08, 09:40 PM posted to rec.aviation.soaring
fcnorton
On Apr 11, 12:02*pm, Randy wrote:
Good afternoon,
When I was in Moriarty last week, *a couple members from the
Randy Teel
N304RS
Hi Randy,
I was getting the same error message last year on my LX7007 after
returning home from the AirSailing XC Camp.
I contacted LX and they emailed me a reset code that I entered into a
setup screen. That fixed the problem and I haven't had it return
since. I don't know if the code will work on the LX5000 but if you
want to try email me via the 304CZ board and I will send it to you.
FC Norton (FCZ)
N304BL
Old April 12th 08, 08:04 AM posted to rec.aviation.soaring
Bruce
Your internal battery has quit - too long without external power is a common cause.
Unfortunately this means your LX will record a file, but it will be invalid for
record or badge flights. Only solution is to get your friendly LX service agent
to replace it and reset the software seal - the failure mode is to assume the
enclosure has been tampered with. It only takes 20 minutes to do, but can mean a
2 week round trip to Slovenia depending on where you are when this happens.
If at a loss contact LXnavigation.si directly - they are very helpful.
Cheers
Bruce
Randy wrote:
Good afternoon,
Randy Teel
N304RS
Old April 12th 08, 03:13 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I can re-seal it for you if necessary. It does sound to me like it will be
necessary. You would need to send it to me. I charge $30 plus the cost of
the return shipping.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Bruce" wrote in message
common cause.
invalid for record or badge flights. Only solution is to get your friendly
LX service agent to replace it and reset the software seal - the failure
mode is to assume the enclosure has been tampered with. It only takes 20
minutes to do, but can mean a 2 week round trip to Slovenia depending on
Cheers
Bruce
Randy wrote:
Good afternoon,
Randy Teel
N304RS
FS: LX-5000 FAI v. 11 Greg Arnold Soaring 0 January 8th 05 01:18 AM
Jeppesen FliteSchool error: Invalid Logon, Limit your Name to alpha-numeric characters only. Jersey Devil General Aviation 0 November 29th 04 09:12 PM
Jep FliteSchool error: Invalid Logon, Limit your Name to alpha-numeric characters only. Jersey Devil Simulators 0 November 29th 04 09:06 PM
FliteSchool error: Invalid Logon, Limit your Name to alpha-numeric characters only. Jersey Devil Products 0 November 29th 04 09:04 PM
[FS] LX 5000 Denis Soaring 0 May 27th 04 10:28 PM
