Three Gallons Per Hour
Old April 13th 08, 06:53 PM posted to rec.aviation.piloting
Phil J
Default Three Gallons Per Hour
Aero News has a story today about Indus Aviation flying a diesel
Thorpedo burning only three gallons of Jet-A per hour. It uses a
WAM-120 turbocharged three-cylinder diesel engine generating 120
horsepower. One drawback of the engine - the installed weight is 279
pounds. But on the plus side it uses a mechanical control unit rather
than electronic. The "projected" TBO is 3000 hours.
Phil
Old April 13th 08, 09:29 PM posted to rec.aviation.piloting
Denny
Hmmm, My BS meter is twitching...This is a BSFC of ~0.142
The very best diesel BSFC is the huge japanese engines used in
container ships at roughly 0.30...
denny
Old April 14th 08, 01:04 AM posted to rec.aviation.piloting
M[_1_]
denny
How did you get SFC of 0.142?
That 3gph might be based on say 50% power (60HP is plenty for cruise
flight on a LSA on a local sight-seeing trip). That'll make SFC: 3 *
6.8 / 60 = 0.34 lb-hr/HP. That's quite doable on a diesel.
Old April 14th 08, 01:13 AM posted to rec.aviation.piloting
Phil J
On Apr 13, 2:10*pm, Bertie the Bunyip wrote:
Phil J wrote in news:748b4d47-77dc-49a8-8252-
Thorpedo burning only three gallons of Jet-A per hour. *It uses a
horsepower. *One drawback of the engine - the installed weight is 279
pounds. *But on the plus side it uses a mechanical control unit rather
than electronic. *The "projected" TBO is 3000 hours.
Phil
Last I heard of that one it was more like 4-5 GPH. That might be an
Imperial measurement.
Bertie
Indus claimed three gallons per hour for a flight from Dallas, Texas
to Lakeland, Florida. I would guess that they throttled back to the
leanest possible cruise. In an EAA news article they are claiming 3.5
to 4 gallons per hour ( http://www.eaa.org/news/2008/2008-04-12_indus.asp
Phil
Old April 14th 08, 01:15 AM posted to rec.aviation.piloting
M[_1_]
BTW, SFC 0.30 is achievable on mid-size ship diesel. The largest ship
diesel engines can do 0.28 lb-hr/HP or less:
http://people.bath.ac.uk/ccsshb/12cyl/
Old April 14th 08, 01:21 AM posted to rec.aviation.piloting
M[_1_]
No doubt that 3gph figure must be an economic cruise power setting,
likely below 50% power.
BTW on a diesel, the combustion is well lean of stoichiometric even at
the max rated power. The air intake is not throttle and the
"throttle" control in a diesel engine is the fuel flow control.
There's no such thing as lean of peak or best power mixture :-) You
reduce the fuel flow and the engine produces less power. You increase
the fuel flow and the engine produces more power - until you reach the
soot limit or other thermo/mechanical limit for the particular engine
and that's the max rated power.
Old April 14th 08, 02:30 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Denny wrote in news:b71e5ad0-64ee-483e-8102-
denny
Well, here they're saying somethign quite different
http://www.wilksch.com/wam-120.html
The 3 GPH might not have been at econ cruise, but it was probably at max
endurance, i.e., just enough to keep them aloft.
Bertie
Old April 14th 08, 03:02 AM posted to rec.aviation.piloting
Peter Dohm
denny
Bertie
And the Wilksch Airmotive numbers for specific fuel consumption are
resoundingly unimpressive for a diesel. It sure is light though!
Peter
Old April 14th 08, 04:50 AM posted to rec.aviation.piloting
Phil J
to Lakeland, Florida. *I would guess that they throttled back to the
the max rated power. *The air intake is not throttle and the
There's no such thing as lean of peak or best power mixture :-) *You
reduce the fuel flow and the engine produces less power. *You increase
See this is what I like about this newsgroup. I am always learning
something new. I've never had direct experience with a diesel engine,
although I suspect that there are going to be more of them in cars as
American fuel prices rise.
Phil
C-172 $20 / hour! C-210 $30 / hour! I found my new job... Ricky Piloting 9 February 14th 08 03:01 PM
1800 Gallons of De-icing fluid... Jay Honeck Piloting 30 January 20th 07 04:39 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Aviation Marketplace 1 February 14th 05 07:36 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Piloting 0 February 12th 05 08:53 PM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Instrument Flight Rules 0 February 12th 05 08:52 PM
