In article
Larry Dighera quotes the NTSB report: Before the collision, the Hawker had been descending toward RNO on a stable northwest heading for several miles, and the glider was in a 30 [degree], left-banked, spiraling climb. . . . Because of the lack of radar data for the glider's flight, it was not possible to determine at which points in each flight each aircraft may have been in the other's available field of view. Although Federal Aviation Regulations (FARs) require all pilots to maintain vigilance to see and avoid other aircraft (this includes pilots of flights operated under IFR, when visibility permits), a number of factors that can diminish the effectiveness of the see-and-avoid principle were evident in this accident. For example, the high-speed closure rate of the Hawker as it approached the glider would have given the glider pilot only limited time to see and avoid the jet. Likewise, the closure rate would have limited the time that the Hawker crew had to detect the glider, and the slim design of the glider would have made it difficult for the Hawker crew to see it. Am I the only one to question this? If the glider was in a 30 degree left banked spiraling climb, we should be able to predict where it was for several minutes prior to the collision --- it was spiraling in the thermal, moving upwards. His nominal thermal airspeed can be looked up for the model of glider; the actual value, and the rate of climb can be determined from the glider pilot. Since the jet was flying in a straight line (rate of descent, if any can be found from radar data), it should be fairly easy to figure where the glider was in the field of view of the jet pilots. As the glider was probably moving about 50 kt, and the jet was reported at 300 kt, the glider would have been within no more than about 9 degrees from directly ahead of the jet. The glider didn't jump in front of the jet. I guess the NTSB did not want to do this calculation. Alan |
Alan wrote:
Likewise, the closure rate would have limited the time that the Hawker crew had to detect the glider, and the slim design of the glider would have made it difficult for the Hawker crew to see it. Am I the only one to question this? If the glider was in a 30 degree left banked spiraling climb, we should be able to predict where it was for several minutes prior to the collision --- it was spiraling in the thermal, moving upwards. His nominal thermal airspeed can be looked up for the model of glider; the actual value, and the rate of climb can be determined from the glider pilot. Since the jet was flying in a straight line (rate of descent, if any can be found from radar data), it should be fairly easy to figure where the glider was in the field of view of the jet pilots. As the glider was probably moving about 50 kt, and the jet was reported at 300 kt, the glider would have been within no more than about 9 degrees from directly ahead of the jet. The glider didn't jump in front of the jet. I guess the NTSB did not want to do this calculation. Lets cut the NTSB (and the Hawker pilots) some slack: sometimes *I* can't spot a glider that is only a mile or two away, even though we're talking to each other, and sometimes, he doesn't see me either! And we aren't closing at 300 knots, maybe not closing at all. It's not just gliders, but the small GA aircraft, too. I'm much more aware of this since I got a Zaon MRX, because I sometimes get an alert but still don't find the airplane. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
"Larry Dighera" wrote in message ... At any rate, even a high aspect ratio glider with minimal frontal area presents a rather significant silhouette when wing-up in a bank if it is seen against contrasting background (unless it is head-on). Perhaps gliders should be fitted with rotating beacon lights in addition to transponders. :-) If seen against a contrasting background, that is key. |
| Thread Tools | |
| Display Modes | |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 67 | May 11th 08 01:20 AM |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Piloting | 155 | May 10th 08 03:45 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 12 | May 1st 08 04:42 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | F. Baum | Soaring | 2 | May 1st 08 04:26 PM |
| Feds Want to Equipe Gliders With Transponders and Radios | Larry Dighera | Soaring | 0 | April 28th 08 05:22 AM |
