the F-15 is 1960s technology - F-22 Raptor is 1980s tech - will therebe a NEW air-superiority fighter?
Old May 6th 08, 11:27 PM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
AirRaid[_2_]
Default the F-15 is 1960s technology - F-22 Raptor is 1980s tech - will therebe a NEW air-superiority fighter?
The F-15 Eagle was designed in the 1960s.
The Advanced Tactical Fighter, YF-23 and YF-22, were developed in the
1980s.
The F-22 Raptor is simply the production version of the YF-22.
Worse, some of the specifications and capabilities that the ATF was
supposed to have, as of the 1980s, was dropped from the YF-22 and
final F-22.
Worse still, the watered-down F-22 came into service 5-10 years later
than originally planned.
Worse yet, instead of 750+ or even 380+, the Air Force is currently
slated to get less than 200 copies.
The F-35 JSF is newer than F-22, but is really a low-end solution
optimized for ground attack and only modest (even if decent) air-to-
air capabilities.
F-22 / F-35 is another high/low mix like the F-15/F-16. But
unlike the F-15, of which there were a decent number (many hundreds),
there will be precious few F-22s. Sure the F-22 can win against 5-
to-1 odds or even 10-to-1 odds. But what about 20-to-1 odds, if the
USAF is pitted against Russia+China within the next 10-15 years?
Also I feel the F-15 was more advanced for the 1970s than the F-22 is
this decade, relatively speaking. Obviously I am not saying the F-15
is more advanced than the F-22, I am saying the F-22 is not as state-
of-the-art now as the F-15 was back then. The F-15 was a
tremendous leap beyond the F-4. Is the F-22 really that much of a
leap beyond the F-15? Maybe in sensors and low-observability
"stealth". The F-22 carries almost the same weapon systems and
weapons load as the F-15. Sure there have been some improvements to
the AMRAAM and Sidewinder, but not a revolution.
I know there will be those that disagree with me, and maybe some who
agree.
I do not believe that unmanned aircraft will take over the air-
superiority / air-supremacy / air-dominance role as quickly as some
think. Not by 2020-2030 anyway. Maybe I am wrong but I don't think
so.
The F-22 is finally in service now (as of a couple years ago). Back
in 1981 and early 1980s, the USAF came up for the requirements for the
ATF, what would, about 25 years later, be in service as the F-22.
What, if anything, is the USAF thinking about in now 2008 for the
future of the air to air mission, as it was in the early 1980s with
the ATF?
I'm thinking of not only the needs of the USAF, but services that
depend on the USAF, such as the U.S Army and U.S. Marine Corps.
The U.S. Navy seems to have given up on advanced high-end fighters.
There is no true direct replacement for the F-14 Tomcat. The Naval
ATF / F-22N was canceled over 15 years ago. I don't believe the Super
Hornet nor the F-35 are going to be able to provide air dominance.
Unless something changes, the entire U.S. armed forces will depend on,
give or take,
183 F-22 Raptors.
Old May 7th 08, 03:44 PM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
Airyx
Default the F-15 is 1960s technology - F-22 Raptor is 1980s tech - willthere be a NEW air-superiority fighter?
this decade, relatively speaking. *Obviously I am not saying the F-15
is more advanced than the F-22, * I am saying the F-22 is not as state-
of-the-art now as the F-15 was back then. * * The F-15 was a
tremendous leap beyond the F-4. * *Is the F-22 really that much of a
leap beyond the F-15? *Maybe in sensors and low-observability
"stealth". * The F-22 carries almost the same weapon systems and
weapons load as the F-15. *Sure there have been some improvements to
When the F-15 came out, a vast many people, especially the GAO and
Aviation Media, claimed that the F-15 was a waste of money because it
offered very little improvement over the F-4. Of couse they looked at
it only in terms of cost vs speed, and the number of on-board kills.
From that perspective, why spend on this money on a jet that is slower
then an F-4 and carries the same number of kills? They failed to take
into account the improvements in sensors, agility, maintainability,
and most importantly, that the design allowed for continuous
improvement as new technologies became available.
So, the F-15A really wasn't that big a leap over an F-4, but as the
APG-70 was added, new ECM, AIM-120, etc, it became a better jet then
the F-4 could ever be.
In terms of sensors, and room for future technologies, the F-22 is a
HUGE leap over anything before it. The basic airframe design may be
from the late 80's but everything else in it is quite new. Also, the
design makes it far easier to replace or add modules to provide it
with new technologies.
There is no true direct replacement for the F-14 Tomcat. * *The Naval
ATF / F-22N was canceled over 15 years ago. *I don't believe the Super
I'm not sure what you are looking for in air dominance. With the
improvements in AAMs, controlling the air comes down to these factors
in order:
1. Find enemy first
2. Shoot first
3. Be able to evade counter shot (if necessary)
#1 is achieved by having good sensors on-board your fighter, but more
importantly by having outstanding sensor fusion that takes-in data
from all sorts of off-board sensors and displays it to the pilot in a
meaningful way. This is what makes the F-22 the best, and the
technology it uses for this is modular, easy to upgrade, and
integrate, and all new. Nothing from the 1980's here.
Also invloved in #1 are stealth, and good ECM
#2 is all about the weapon, and the sensors used to guide it.
#3 is about short bursts of agility, and speed. We are unlikely to see
jets going through sustained maneuvers to gain a good firing position
(dogfights), since reliable shots can now be taken at long ranges and
from almost any aspect.
Many have said in the past that the days of the dogfight were over,
and they were proven wrong. Well, it was only a matter of time until
the technology matured.
So, to that end, the Superhornet, and F-35 will do just fine, and the
F-22 could very well be our last manned fighter. Could use a bunch
more of them though.
Old May 8th 08, 04:51 AM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
Gernot Hassenpflug[_2_]
Default the F-15 is 1960s technology - F-22 Raptor is 1980s tech - will there be a NEW air-superiority fighter?
Airyx writes:
this decade, relatively speaking. /../
it offered very little improvement over the F-4. /../ They failed to
take into account the improvements in sensors, agility,
maintainability, and most importantly, that the design allowed for
continuous improvement as new technologies became available.
Very good point.
in order:
1. Find enemy first
2. Shoot first
In WWII the "Big Blue Blanket" was a means to blunt enemy attacks
before they had a chance to close to uninterceptable distances. This
despite massive improvements in sensors in the USN during the war, and
the respective lack thereof on the enemy side. Point No.1 cannot be
overstressed, and neither can its implementation: there has to be
redundancy (sensors, sensor types and aircraft numbers; and now fusion
between them to synthesize greater ability than the individuals could
have had by themselves) to do the job properly. However, "optimizing"
is going to be very harmful if it tries to cut down on "redundancy" as
"unneccessary". The reason for this is that any "optimization" by
definition ignores possible changes in the enemy capabilities and
"unexpected" (by those with no experience of hard reality; or no
imagination g) developments that may affect the very model on which
the operational depoloyment of aircraft and sensors is based.
The distances got bigger, but the mental game remains the same at its
co outsmarting the other guys. Still, in practice guys (and girls)
that can transition to this much much more complex web of combat are
probably going to be both similar and slightly different from people
who excel in "dogfights". Teamwork matters too so all types have a
role, neuro-surgeon type specialist detail experts as well as those
general practitioner types with a genius for overall diagnosis.
Exactly.
BOFH excuse #139:
UBNC (user brain not connected)
Old May 9th 08, 02:32 PM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
The Advanced Tactical Fighter, *YF-23 and YF-22, were developed in the
1980s.
supposed to have, as of the 1980s, was dropped from the YF-22 *and
final F-22.
Worse still, *the watered-down F-22 came into service 5-10 years later
The F-35 JSF *is newer than F-22, but is really a low-end solution
optimized for ground attack and only modest (even if decent) *air-to-
air capabilities.
F-22 / F-35 *is another high/low mix like the F-15/F-16. * * But
there will be precious few F-22s. * Sure the F-22 can *win against 5-
agree.
superiority / air-supremacy / air-dominance role * as quickly as some
think. *Not by 2020-2030 anyway. Maybe I am wrong but I don't think
so.
The F-22 is finally in service now (as of a couple years ago). * *Back
the ATF?
Well, the navy dead-ended themselves with fighter aircraft
and movies of fighter aircraft. The idiots have been told since
like 1950, that the two mix like nuclear reactors and machine
guns.
Which is really where the cruise missiles, GPS, and internet came
from
for the idiots.
And the air force hasn't invested in anything other than stealth
technology, since the wanks first saw the Blackbird. So their
aircraft isn't really an aircraft development program,
it's a leen on your grandchildren's homes.
give or take,
183 F-22 Raptors.
Old May 9th 08, 09:11 PM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
J a c k
So their aircraft isn't really an aircraft development program,
There'll be mighty lean times trying to pay off that lien.
Jack
Old May 10th 08, 10:57 AM posted to rec.aviation.military,alt.military,us.military.army,us.military,rec.aviation.military.naval
hcobb
How can the United States Navy expect to win the war, when it has no
fighter that can match the performance of the main enemy fighter?
Won't the Japanese Zero sweep the USN's aircraft from the skies? ;-)
-HJC
GAO: Joint Strike Fighter: Management of the Technology Transfer Process. Mike Naval Aviation 0 March 16th 06 02:38 PM
"Why Raptor? The Logic of Buying the World's Best Fighter" Mike Military Aviation 0 August 11th 04 03:20 PM
Airpower: India threatens US air superiority Krztalizer Military Aviation 71 July 10th 04 08:06 AM
Air Force Raptor fighter starts operational trials, By John J. Lumpkin Otis Willie Military Aviation 0 May 1st 04 10:18 PM
USAF Fighter-Attack SPO members from the 1980s? R Haskin Military Aviation 0 September 20th 03 12:06 PM
