New GA fuel?
Old May 8th 08, 03:46 PM posted to rec.aviation.owning
Mike Noel
Default New GA fuel?
On AvWeb:
New GA Fuel Promises Better Range, Lower Cost
"Not only can our fuel seamlessly replace the aviation industry's standard
petroleum fuel [100LL], it can outperform it," says John Rusek, a professor
at Purdue University and co-founder of Swift Enterprises. The company
recently unveiled a new general aviation fuel that it says will be less
expensive, more fuel-efficient and environmentally friendlier than any on
the market. Unlike other alternative fuels, Rusek said, SwiftFuel is made of
synthetic hydrocarbons that are derived from biomass, and it can provide an
effective range greater than 100LL, while costing about half as much to
produce. "Our fuel should not be confused with first-generation biofuels
like E-85 [85 percent ethanol], which don't compete well right now with
petroleum," Rusek said. Patented technology can produce the 1.8 million
gallons per day of fuel used by GA in the U.S. by using just 5 percent of
the existing biofuel plant infrastructure, the company said.
The synthetic fuel is 15 to 20 percent more fuel-efficient, has no sulfur
emissions, requires no stabilizers, has a 30-degree lower freezing point
than 100LL, introduces no new carbon emissions, and is lead-free, Rusek
said. In addition, he said, the components of the fuel can be formulated
into a replacement for jet/turbine fuels. The company now is working with
the FAA to evaluate the fuel.
Best Regards,
http://photoshow.comcast.net/mikenoel
Old May 8th 08, 05:26 PM posted to rec.aviation.owning
Al G[_1_]
"Mike Noel" wrote in message
news
On AvWeb:
professor at Purdue University and co-founder of Swift Enterprises. The
company recently unveiled a new general aviation fuel that it says will be
less expensive, more fuel-efficient and environmentally friendlier than
any on the market. Unlike other alternative fuels, Rusek said, SwiftFuel
is made of synthetic hydrocarbons that are derived from biomass, and it
can provide an effective range greater than 100LL, while costing about
half as much to produce. "Our fuel should not be confused with
first-generation biofuels like E-85 [85 percent ethanol], which don't
compete well right now with petroleum," Rusek said. Patented technology
can produce the 1.8 million gallons per day of fuel used by GA in the U.S.
by using just 5 percent of the existing biofuel plant infrastructure, the
company said.
Best Regards,
I saw this. It sounds almost too good to be true. I am curious about the
process used. Biomass? What kind of biomass? It actually makes sense for a
startup company to shoot for a market that already has a high price, and is
about to lose it's only source.
Al G
Old May 8th 08, 08:14 PM posted to rec.aviation.owning
Gig 601Xl Builder
news
On AvWeb:
company said.
Best Regards,
Al G
Remember, Soylent Green is people.
Old May 8th 08, 11:56 PM posted to rec.aviation.owning
Howard
news
On AvWeb:
company said.
Best Regards,
Don't know anything about this but first thing I thought of was the miracle
of "cold fusion". I can only hope it is true.and it is available.
Old May 9th 08, 04:51 AM posted to rec.aviation.owning
Orval Fairbairn[_2_]
news
On AvWeb:
company said.
Best Regards,
At first glance, it appears that it would have to be one of the
aromatics or paraffin-based hydrocarbons to get that kid of increase in
output and octane rating.
You would probably have to replace all of the hoses on switchover, as
the MAterials take on a "set," based on the type of fuel being used
(petroleum or aromatic).
Remove _'s from email address to talk to me.
Old May 9th 08, 12:06 PM posted to rec.aviation.owning
Lou
Just remember, you will know how true this is when you never hear
about
it again. If there is such a fuel the oil companies will take care of
it.
Lou
Old May 10th 08, 08:25 AM posted to rec.aviation.owning
Alan[_6_]
In article "Al G" writes:
If it were true, these folks should be producing all they can. After all,
they could sell the stuff at or near current prices and make a bundle, and use
that to fund their expansion.
It would be wonderful if such were true and the processes were available to
have the country produce large amounts of this fuel (which should be an excellent
auto fuel from the description), but if it were, they would probably have more
on their web site than an announcement of what web site design team they had
hired to do the page.
Alan
Old May 11th 08, 12:13 AM posted to rec.aviation.owning
Mike Noel
Here is an earlier article about this fuel:
http://www.checkbiotech.org/green_Ne...infoId=1692 2
Best Regards,
"Alan" wrote in message
In article "Al G"
writes:
sulfur
with
is
all,
use
to
excellent
more
had
Alan
Old May 11th 08, 01:17 AM posted to rec.aviation.owning
terry
news
On AvWeb:
company said.
Best Regards,
* * I saw this. It sounds almost too good to be true. I am curious about the
There are 5 components all from biomass. Here is a link to the
patent.
http://www.wipo.int/pctdb/en/wo.jsp?...2008013922&DIS...
Old May 19th 08, 12:29 AM posted to rec.aviation.owning
On Sat, 10 May 2008 17:17:23 -0700 (PDT), terry
news
On AvWeb:
company said.
Best Regards,
patent.
It appears to be a patent of a formulation of conventional renewable
components so I'm surprised they were issued a patent.
It's not what I'd call a "synthetic fuel", but rather a formulation of
organic components (unless I missed something) "To Me" synthetic
indicates non organic compounds used in the fuel. This I might call
unconventional, but not synthetic.
As to the energy component, that depends on the molecular structure of
the compounds. Just as diesel fuel has a much higher energy content
than gasoline I see no reason whey with the formulation of components
listed they couldn't get more (or less) energy per unit volume/Gallon.
OTOH whether that extra energy would actually be useful in a standard
aircraft engine is something else.
Roger (K8RI) ARRL Life Member
N833R (World's oldest Debonair)
www.rogerhalstead.com
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
