GPS for PDA
Old May 20th 08, 06:42 PM posted to rec.aviation.soaring
Morten Wartou
Default GPS for PDA
Hi!
I recently bought a Holux M-1200 bluetooth GPS receiver to be used with my
PDA. It sort of works - but has one "minor" problem - when I curve, it often
can't acquire good signal and gets really confused. Ofcourse I could just
avoid curving, but living in a very flat country, it's the only way I can
stay up.
Has anyone else had these kind of problems with the M-1200?
Any suggestions for a GPS receiver (preferrably bluetooth, but CF could be a
possibility)? I like the M-1200's ability to do 5 updates/sec. and I'd like
the new one to do that too.
Best regards,
Morten Wartou
Old May 20th 08, 07:27 PM posted to rec.aviation.soaring
Cats
Default GPS for PDA
On May 20, 6:42*pm, "Morten Wartou"
Hi!
stay up.
You could experiment with where you put the bluetooth GPS in the
glider. Or, if you use a data logger you could see about taking a
feed from that to the PDA - that will mean that you can be absolutely
sure that your trace won't include any airspace infringements!
However you might well not get 5 updates/second going down that route.
Old May 20th 08, 07:41 PM posted to rec.aviation.soaring
brianDG303
Default GPS for PDA
On May 20, 11:27 am, Cats wrote:
On May 20, 6:42 pm, "Morten Wartou"
Hi!
stay up.
I have great results using a 'freedom keychain GPS' into an IPAQ 3790.
http://blog.treonauts.com/2008/02/freedom-keychai.html
but I don't think the 5/sec. update is going to happen. Nice $100
backup GPS though.
Old May 20th 08, 11:44 PM posted to rec.aviation.soaring
Eric Greenwell
Default GPS for PDA
be a possibility)? I like the M-1200's ability to do 5 updates/sec. and
I'd like the new one to do that too.
Why do you like the fast update rate? It takes my glider at least a
second to even begin doing anything.
Old May 21st 08, 02:23 PM posted to rec.aviation.soaring
Default GPS for PDA
On May 20, 10:42*am, "Morten Wartou"
Hi!
stay up.
Best regards,
* * Morten Wartou
Hello
I use a holux 1000 with good results on a palm PDA. I orderd a BT blue
with auto on and sleep, but this unit would drop out and go into sleep
mode . The 1000 works great I can pick up a signal in the house with
no problem. Jim M
