file conversion from .fil to .igc
Old May 21st 08, 12:33 AM posted to rec.aviation.soaring
Fred[_4_]
Default file conversion from .fil to .igc
I need a way to convert a .fil file to an .igc file. It is from a
filser GPS and I need to view it with Winscore.
SeeYou software can read it.
Fred
Old May 21st 08, 02:10 AM posted to rec.aviation.soaring
JS
File / Save As.
Old May 21st 08, 04:03 AM posted to rec.aviation.soaring
st4s03
On May 20, 5:33*pm, Fred wrote:
I need a way to convert a .fil file to an .igc file. *It is from a
Fred
Try this web site: http://www.gpsvisualizer.com/gpsbabel/
Old May 21st 08, 07:26 AM posted to rec.aviation.soaring
Andrej Kolar[_2_]
There's no reason why SeeYou would not open the FIL file through File
Open if the FIL file is not corrupt. Once you have opened the FIL
file you should save it through File Save As.
If this does not work, send it to support at naviter dot com and we
will have a look at it.
Andrej Kolar
glider pilots use
http://www.naviter.com
VHS to DVD conversion tom Home Built 0 October 21st 07 04:50 AM
VW Conversion [email protected] Home Built 4 June 3rd 07 07:43 PM
cub to sua conversion Tuno Soaring 2 March 23rd 07 12:23 PM
LS-4 to LS-4a conversion Dan Peters Soaring 1 September 1st 06 01:29 AM
LS-4 to LS-4a conversion Dan Peters Soaring 1 August 29th 06 06:50 AM
