BNC installation
Old June 24th 08, 04:28 PM posted to rec.aviation.soaring
JJ Sinclair
Default BNC installation
I'm about ready to splice on a good fin & boom to a badly broken
Puchacz fuselage. Made a clean cut 56" aft of the aft lift fittings,
glued in a sleeve, jigged up the two pieces (both sides straight, top
& bottom straight, fin vertical, lift fittings horizontal), spliced
the push-rod, hooked up the TE tube, now all I have to do is splice
the radio cable, right? Always hated trying to solder that little
center post on the BNC, especially working inside a fuselage half with
short leads. Found a BNC crimper from Aircraft Spruce & Specialty for
about $200 bucks with proper die and a hand full of BNC's. Works slick
as snot, just slide on the sleeve, trim the cable as before, slip on
the center post and crimp it, then slide on the BNC body, shove the
sleeve down over the exposed shield and crimp it also. That's it, all
done!
I installed one male and one female connector (legal in all states).
Some may wish to use two females with a male to male coupler (only
legal in some states).
JJ
WX-950 installation Kyprianos Biris Owning 5 October 23rd 07 02:37 PM
US ELT Installation mhr Soaring 57 December 31st 05 08:39 PM
installation xcsoar junior Soaring 0 February 23rd 04 12:50 PM
2-33 battery installation Kurt Soaring 2 January 27th 04 02:36 PM
EGT installation Andre Home Built 4 August 27th 03 09:33 AM
