Welded Patch Repair question
Old July 19th 08, 05:08 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welded Patch Repair question
I'm working with 4130.
I have a piece of tubing with a series of rust holes which do not
cover an area greater than 1/2 ", so it appears a welded patch repair
would be appropriate.
Reading 43.13,, Figure 4-36, it appears the patch tube will have to be
expanded in diameter in order to fit over the injured tube (can't slip
the patch over the injured tubefrom an end).
Will there be any problem if I heat the patch so I can open open it
and slip it over the injured tubing? - Mike
Stressed Skin Repair Question RPM the A&P Home Built 9 July 16th 08 05:59 AM
4130 can't be OA welded? wright1902glider Home Built 61 January 4th 08 06:19 AM
Magneto Repair vs Overhaul Question. Ebby Home Built 6 February 24th 07 06:55 PM
172 Repair question Brad Mallard Home Built 2 June 11th 04 03:54 AM
172 Repair question Brad Mallard Aviation Marketplace 3 June 11th 04 03:54 AM
