Paul Gaines of Composite Solutions has completed his relocation of his
composite aircraft repair facility to Kingman, AZ. It is a 10,000 sq ft dedicated facility located on Flightline Drive at KIGM. Thanks, Paul A. Gaines |
On Aug 7, 4:25 pm, Paul Gaines wrote:
Paul Gaines of Composite Solutions has completed his relocation of his composite aircraft repair facility to Kingman, AZ. It is a 10,000 sq ft dedicated facility located on Flightline Drive at KIGM. Thanks, Paul A. Gaines Kingman? Why Kingman? No-one lives there - it's the middle of nowhere! Mike |
On Aug 8, 8:44*am, Mike the Strike wrote:
it's the middle of nowhere! To the optimist that's described as "centrally located" Actually probably quite a good position to serve southern California, Arizona, and Colorado I would think. Andy |
At 15:49 08 August 2008, Andy wrote:
On Aug 8, 8:44=A0am, Mike the Strike wrote: it's the middle of nowhere! To the optimist that's described as "centrally located" Actually probably quite a good position to serve southern California, Arizona, and Colorado I would think. Andy Yes...the location and size of the airport is the reason. Soaring should be fantastic (been a bit busy to try it out yet) and the airport is good for general aviation composite work as well. We are not too far from the Grand Canyon and Vegas...in case we want a break! |
and southern Nevada
Paul.. there is a glider club at Jean NV and Beatty NV One member flies his ASH26E from an airport just east of the dam on Hwy93 BT "Andy" wrote in message ... On Aug 8, 8:44 am, Mike the Strike wrote: it's the middle of nowhere! To the optimist that's described as "centrally located" Actually probably quite a good position to serve southern California, Arizona, and Colorado I would think. Andy |
| Thread Tools | |
| Display Modes | |
| Repair shop new location | Paul Gaines[_2_] | Soaring | 0 | August 8th 08 01:25 AM |
| Dittel radio repair location? | Sam Discusflyer | Soaring | 2 | July 21st 07 11:52 PM |
| Q: repair shop in Southern CA or AZ? | Roger Worden | Soaring | 10 | March 4th 06 10:40 AM |
| Running a repair shop | Greg Esres | Owning | 15 | May 24th 04 06:06 PM |
| Anyone in France or Germany, nearest repair shop to Limoges Bellegarde,contact info | goneill | Soaring | 1 | October 28th 03 05:03 PM |
