Flanker vs F-15
Old March 24th 04, 11:19 PM
Boomer
Default Flanker vs F-15
I'm no aerodynamicist but I've been running some numbers and noticed some
interesting things.
The SU-27 is credited with being more manueverable than F-15 and yet F-15
has a higher TTW number (except at gross) and a lower wing loading by a
large margin (again except at gross). The SU should develope more body lift
than Eagle, but at best it looks like a wash at low altitudes, with Eagle
turning better than SU at altitude.
Any thoughts? Am I missing something large here? The Su's lerx's and higher
aspect wing should make a positive differance at low level and low speeds
but I dont think it would make up for the other numbers. Eagle should have a
20% better wing loading and about a 14% better TTW number.
Curiosity killed the cat, and I'm gonna find out why!
Old March 25th 04, 12:11 AM
John Mullen
"Boomer" wrote in message
interesting things.
lift
higher
a
The Su has a pull-through fuction on the fbw ISTR. Might be a factor?
John
Old March 25th 04, 01:18 AM
Michael Kelly
Probably not since the the F-15C isn't FBW and only has an overload
warning function. You can over G a F-15C.
Michael Kelly, Bone Maintainer
John
Old March 25th 04, 09:44 AM
Boomer
yes Flankers have a switch which over rides the FBW limits, that's the only
way they can do the "Cobra" manuever. As I recall F-15s started out with
hydro controls with FBW as back up, then later models went fully fly by
wire.
"Michael Kelly" wrote in message
m...
John
Old March 25th 04, 11:41 AM
R Haskin
m...
Actually fly-by-wire aircraft can be over-Gd -- it happens to F-16s all the
time.
The F-15, while not "fully" fly-by-wire, has a primary flight control system
that is FBW (called the CAS, or Control Augmentation System) and a
hydromechanical backup system.
Old March 25th 04, 05:45 PM
Jeff Crowell
time.
Yabbut, isn't that a case of a Lawn Dart pulling max G and
then hitting turbulence, etc.?
Jeff
Old March 26th 04, 02:41 AM
Mary Shafer
On Thu, 25 Mar 2004 02:44:04 -0600, "Boomer"
wire.
The F-15 started as conventional with conventional backup and an
analog FCS. It eventually went to a digital FCS, but not to FBW.
The E might be FBW, but the A-D aren't.
Mary
Mary Shafer Retired aerospace research engineer
Old March 26th 04, 05:28 AM
David E. Powell
There are two really important questions:
1. What are the other odds? (AWACS, support aircraft, SAM defenses, range to
bases, numbers on each side, etc.)
2. Who are the pilots?
Both of these are quite critical to the equation.
DEP
Old March 26th 04, 06:24 AM
Michael Kelly
time.
Agreed. The Bone is a 2 channel FBW on one side with a hydromechanical
stability augmented system on the other side. There are no limiters on
the FBW or stability aug so over G's happen all the time. Limiters on
the 16 make it harder to over G but not impossible.
IIRC my F-15 test pilot former colleague described the F-15C as fully
hydromechanical and the Echo's as you did. BTW saw you the other day on
the history channel. Good interview.
Cheers,
Old March 26th 04, 06:29 AM
Michael Kelly
I could see too high of an onset rate, or pulling a turn as you
decelerated through the sound barrier. The latter case would be a very
good candidate if pulling a turn close to the limiter because of the
forward shift in the aerodynamic center going from supersonic to subsonic.
Jeff
OT-ish Su27 Flanker fans *might* enjoy... Andrew MacPherson Military Aviation 0 February 1st 04 12:33 PM
F-22 Comparison robert arndt Military Aviation 39 December 4th 03 05:25 PM
[New WebSite] Su-27 Flanker Benoit Military Aviation 0 November 11th 03 05:54 PM
Su-27SK(Upgraded), Su-27KUB & new Flanker book Thomas J. Paladino Jr. Military Aviation 6 July 28th 03 08:53 PM
RIAT Fairford Reviews John Cook Military Aviation 4 July 21st 03 08:36 PM
