mounting a PCAS on the glareshield
Old September 29th 08, 09:31 PM posted to rec.aviation.owning
Mike Noel
Default mounting a PCAS on the glareshield
Has anyone found an elegant way to mount a PCAS unit like the Zaon XRX on a
compound curved glareshield?
I'm using the provided Velcro in one corner, various sizes of self-adhesive
bumpers in two other corners, and the fourth corner is left dangling about
an inch in the air. I've had to add a bit of superglue to the pads so the
adhesive doesn't start sliding around when the cockpit is hot. The unit
works well with the 496 TCAS input, but I would like a more secure and level
mount on the glareshield.
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
http://photoshow.comcast.net/mikenoel
Old September 30th 08, 12:06 AM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
"Mike Noel" wrote in message
a compound curved glareshield?
Ez
Step 1) get a chunk of 1/8 lexan from the local hardware store - have them
cut it to, oh, about 6 inches by10 inches or so.
Step 2) send the wife to visit her mom for the afternoon (important - do
this before step 3)
Step 3) put the lexan in the oven for a couple hours at about 180 F. to
drive off the water - then raise the temp. to about 250 or 300 wait for it
to get rubbery
Step 4) wrap the lexan around a chunk of 1x6.
You will now have a platform that is about 6 inches by about 5 3/4 inches
wide with two "feet" that will straddle the hump on the glare shield. If it
has a strong compound curve, you will have to cut away the middle of each
side to make 4 individual feet (or make adjustments with a heat gun).
Stick the lexan to the PCAS with double side tape and put the velcro on the
feet.
A custom mount with no muss, no fuss (unless your wife catches you putting
the lexan in her oven)...
Geoff
Old September 30th 08, 12:08 AM posted to rec.aviation.owning
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in message
on a compound curved glareshield?
Ez
them cut it to, oh, about 6 inches by10 inches or so.
this before step 3)
it to get rubbery
inches wide with two "feet" that will straddle the hump on the glare
shield. If it has a strong compound curve, you will have to cut away the
middle of each side to make 4 individual feet (or make adjustments with a
heat gun).
the feet.
putting the lexan in her oven)...
oops - forgot - use a cookie sheet and /or tinfoil under the lexan when you
put it in the oven.
Geoff
PA-28 Glareshield Replacement Marco Leon[_4_] Owning 8 January 11th 08 09:33 PM
GPS intrference from Zaon PCAS ?? Carl Soaring 9 May 31st 07 06:12 AM
Glareshield Overhaul? Mike Spera Owning 7 March 24th 07 12:34 AM
ASW20A Glareshield needed Tim Mara Soaring 0 April 19th 04 05:17 AM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 01:39 PM
