Adhesive Recommendation?
Old October 7th 08, 03:40 PM posted to rec.aviation.owning
Steve - KDMW
Default Adhesive Recommendation?
One of the rubber pads came off one of my rudder pedals the other day.
Anybody have a good adhesive they can recommend for rubber to metal?
Steve
PA28-151
KDMW
Old October 7th 08, 04:35 PM posted to rec.aviation.owning
Mike Noel
One of the best all-around adhesives I have found is 'Goop'. It seems to
form a tough bond with almost anything.
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
http://photoshow.comcast.net/mikenoel
"Steve - KDMW" wrote in message
Steve
PA28-151
KDMW
Old October 7th 08, 06:19 PM posted to rec.aviation.owning
Ross
Probably a good recommendation. I was going to suggest a contact cement.
Be sure all surfaces are clean and follow the label instructions.
Regards, Ross
C-172F 180HP
KSWI
Old October 7th 08, 06:33 PM posted to rec.aviation.owning
JGalban via AviationKB.com
That was a recurring problem for my Cherokee. In the desert heat,
adhesives tended to lose their grip over time. I solved the problem by
using black zip ties to hold the rubber pads on the pedals.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200810/1
Old October 7th 08, 07:30 PM posted to rec.aviation.owning
Marco Leon[_5_]
"JGalban via AviationKB.com" u32749@uwe wrote in message
news:8b51498a7260d@uwe...
I did the same thing to mine in the Warrior. Put them on about 8 years ago
and they're still holding the pads onto the pedal. (Of course now that I
posted this message they'll probably fall off tomorrow!)
Marco
Old October 7th 08, 07:45 PM posted to rec.aviation.owning
Jon Woellhaf
I've had success using 3M auto trim adhesive.
Steve
PA28-151
KDMW
Old October 8th 08, 08:28 PM posted to rec.aviation.owning
Lou
What do they use for golf clubs?
If anything is going to slip it would be
the clubs.
Adhesive [email protected] Owning 7 August 29th 06 05:15 AM
Adhesive [email protected] Restoration 3 August 25th 06 04:41 AM
Adhesive [email protected] Owning 6 August 23rd 06 06:33 PM
adhesive [email protected] Piloting 2 August 20th 06 01:30 PM
structural adhesive circio0 Home Built 5 May 30th 06 10:34 AM
