Grob 103 Twin II Brake Master Cylinder
Old October 22nd 08, 01:30 PM posted to rec.aviation.soaring
Mike McCarron
Default Grob 103 Twin II Brake Master Cylinder
My club has a 1983 Grob 103 Twin II that needs a new master cylinder. Over
the years the Grob factory has made changes to the system without full
documentation and as a result the US distributor can not be sure of how I
go about purchasing the proper master cylinder for this glider.
If you or anyone you know has replaced the master cylinder on a vintage
Grob 103 Twin II recently I would appreciate your input on where I might
purchase the correct system.
Thank you,
Old October 22nd 08, 03:41 PM posted to rec.aviation.soaring
JJ Sinclair
If memory serves me, its a motorcycle master cylinder BMW? I believe
they cut it down from the original, good luck getting your inspector
to sign off on installing it!
JJ
Thank you,
Old October 22nd 08, 04:00 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
JJ,
I did purchase a master cylinder from a BMW motorcycle dealer that did fit
in place. Unfortunately it did not function properly. It was properly
bled and all but it did not work. I don't know what to do next. There
must be at least 100 of these gliders in the US that will need a master
cylinder replacement in the future. I don't see how we can junk a $30K
glider for lack of a functioning master cylinder.
Thanks for your comment,
MC
JJ
Over
how
I
vintage
might
Thank you,
Old October 22nd 08, 04:22 PM posted to rec.aviation.soaring
JJ Sinclair
Why didn't it work, Mike? Hydraulics are hydraulics, the Clevland
brake slave cylinder doesn't know (or care) where that pressure is
coming from? Make sure you have compatible seals. What type fluid does
BMW use? Can't mix the red stuff with the clear stuff.
JJ
JJ,
MC
JJ
Over
how
I
vintage
might
Thank you,
Old October 22nd 08, 04:45 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
JJ,
I used Dot 3 fluid with compatible O ring on the slave cylinder. The cap
on the BMW master cylinder said to use DOT 3/4 brake fluid only.
MC
JJ
JJ,
fit
properly
There
master
$30K
MC
JJ
cylinder.
Over
full
how
I
vintage
might
Thank you,
Old October 22nd 08, 05:01 PM posted to rec.aviation.soaring
bumper
Yup, what JJ said. The "red stuff" is Mil Spec 5606 hydraulic oil and is
compatible with Buna-N O-rings and seals. It's also commonly used in the USA
for most small GA aircraft.
DOT automotive brake fluid, the "clear stuff", most often glycol-ether
based, and is compatible with EPDM rubber seals.
If you are switching parts from one fluid to the other, you gotta change the
rubber stuff.
bumper
"JJ Sinclair" wrote in message
JJ
JJ,
fit
MC
JJ
Over
how
I
vintage
might
Thank you,
Old October 22nd 08, 05:22 PM posted to rec.aviation.soaring
Uncle Fuzzy
rubber stuff.
bumper
JJ
JJ,
fit
in place. *Unfortunately it did not function properly. *It was properly
bled and all but it did not work. *I don't know what to do next. *There
cylinder replacement in the future. *I don't see how we can junk a $30K
MC
JJ
Old October 22nd 08, 06:33 PM posted to rec.aviation.soaring
Uncle Fuzzy
rubber stuff.
bumper
JJ
JJ,
fit
MC
JJ
Over
how
I
vintage
might
Thank you,
Mike- Hide quoted text -
- Show quoted text -
In our club Grob 103, the master cylinder is a Magura motorcycle front
brake master cylinder. *Magura makes parts for a bunch of bikes, and
for the aftermarket. Motorcycle front brake master cylinders come in a
variety of piston diameters. *They are also somewhat weird to bleed.
They won't develop pressure unless almost all of the air is bled out
of the system. *"Pumping" one endlessly has no effect. *On a bike, one
trick is to zip tie the handle so that the lever is halfway to the
grip, crack the bleeder on the caliper (with a tube on it to direct
the drainage), and walk away for a couple hours and let gravity do
some work for you. *Much quicker is to zip tie the lever halfway, and
use a small vacuum pump rig to PULL the fluid through. *Once most of
the air is gone, you should be able to develop some pressure to
complete the bleeding in the normal manner. *YES to DOT 3/4. *NO to
Mil Spec 5606 hydraulic oil. *As an experiment, I tossed some
motorcycle brake bits in a jar of 5606. *They turned into something
other than brake bits pretty quickly.- Hide quoted text -
Clarification on the quicker way to purge the air out: Zip tie the
lever at half travel, use a vacuum pump ON THE CALIPER BLEEDER to pull
brake fluid through. Hope this helps
Old October 22nd 08, 07:00 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
How can one tell where to position the lever? Half way through it's total
travel or some other location?
MC
At 16:33 22 October 2008, Uncle Fuzzy wrote:
On Oct 22, 8:22=A0am, Uncle Fuzzy wrote:
and
i=
s
in
th=
e USA
glycol-ether
chang=
e the
rubber stuff.
bumper
is
doe=
s
JJ
JJ,
that
d=
id
fit
in place. =A0Unfortunately it did not function properly. =A0It
was
p=
roperly
bled and all but it did not work. =A0I don't know what to do
next.
=A0There
mas=
ter
cylinder replacement in the future. =A0I don't see how we can
junk
a=
$30K
MC
believ=
e
inspecto=
r
JJ
cylin=
der.
Over
without=
full
sure
of
how
I
glider.
a
vintage
where
I
might
Thank you,
brake master cylinder. =A0Magura makes parts for a bunch of bikes, and
variety of piston diameters. =A0They are also somewhat weird to bleed.
of the system. =A0"Pumping" one endlessly has no effect. =A0On a
bike,
on=
e
some work for you. =A0Much quicker is to zip tie the lever halfway,
and
use a small vacuum pump rig to PULL the fluid through. =A0Once most of
complete the bleeding in the normal manner. =A0YES to DOT 3/4. =A0NO
to
Mil Spec 5606 hydraulic oil. =A0As an experiment, I tossed some
motorcycle brake bits in a jar of 5606. =A0They turned into something
Old October 22nd 08, 07:39 PM posted to rec.aviation.soaring
bumper
Hook up vacuum pot to caliper bleed valve, open valve a turn, apply vacuum,
squeeze lever slowly until fluid flows out of bleed valve. Be sure to add
fluid to reservoir as level drops.
bumper
"Mike McCarron" wrote in message
MC
and
i=
s
in
th=
e USA
glycol-ether
chang=
e the
rubber stuff.
bumper
is
doe=
s
JJ
JJ,
that
d=
id
fit
was
p=
roperly
next.
=A0There
mas=
ter
junk
a=
$30K
MC
believ=
e
inspecto=
r
JJ
cylin=
der.
Over
without=
full
sure
of
how
I
glider.
a
vintage
where
I
might
Thank you,
bike,
on=
e
and
to
Grob 103 Twin II (non acro) manual YFCpilots Soaring 1 August 27th 08 08:40 PM
Grob Twin III Must read! [email protected] Soaring 3 June 9th 08 08:08 AM
Grob Twin Astir Tailshaking Peter Soaring 11 January 15th 07 12:54 AM
looking for good brake master cyls for homebuilt. clare @ snyder.on .ca Aviation Marketplace 0 March 28th 04 06:13 AM
Need G-103 Acro Master Cylinder Ray Lovinggood Soaring 5 September 30th 03 04:39 AM
