is it reasonable to assume that if presented with a choice of grit
sizes (20.40.80), that 80 would be the finest? like sandpaper roughness - Mike |
On Sat, 01 Nov 2008 05:40:16 -0400, Michael Horowitz
wrote: is it reasonable to assume that if presented with a choice of grit sizes (20.40.80), that 80 would be the finest? like sandpaper roughness - Mike ballottini (glass beads) comes in a two letter designation. I used AH grade after some experimentation. it worked best on the steel tubes of the Auster. when bead blasting an aircraft component you need to take into account the fatigue characteristics of the resultant blasted surface. for this reason you need round particles not sharp grit. we have sandy soils over here in Perth. some of the most effective bead blasting media I used was fine round particle washed quartz sand just beside the neighbouring hangar. use the appropriate style of grit for aviation. Stealth Pilot |
| Thread Tools | |
| Display Modes | |
| size comaprison: B-36 & B-29 | centerplace | Aviation Photos | 3 | January 11th 08 11:32 PM |
| Sandblasting reference? | Michael Horowitz | Home Built | 7 | November 20th 07 08:01 AM |
| File size | Maple1 | Aviation Photos | 1 | June 16th 07 04:31 AM |
| What size hole saw do I use? | [email protected] | Home Built | 22 | July 16th 05 09:21 AM |
| Size does matter | HECTOP | Piloting | 59 | May 14th 04 12:48 AM |
