I have some questions concerning the Stewart AFS.
I'll contact them directly during the week but would like to hear what the group says. Do you know where the STC begins? By that I mean do we need to start with bare metal and use their propriety primer, or will zinc oxide or 2 part primer work with their glue and their primer is just a convenience. For metal prep that will not be in contact with fabric or their glue, they go into detail about using their products. I had planned on using Rustoleum spray paint where there glue was not involved; again, are they just offering their primer as a convenience? - Mike |
"Michael Horowitz" wrote in message
... I have some questions concerning the Stewart AFS. I'll contact them directly during the week but would like to hear what the group says. Do you know where the STC begins? By that I mean do we need to start with bare metal and use their propriety primer, or will zinc oxide or 2 part primer work with their glue and their primer is just a convenience. For metal prep that will not be in contact with fabric or their glue, they go into detail about using their products. I had planned on using Rustoleum spray paint where there glue was not involved; again, are they just offering their primer as a convenience? - Mike I don't know the answer to your specific question, and the Rustoleum formula may have been changed and improved; but my own experience from 30 years ago is that MOST rattle can paints, including Rustoleum primer, will NEVER fully air dry in a humid climate. You only have to back them hot enough to bring down the percentage of humidity. 20, or at most 30, degrees fahrenheit above ambient will do the job overnight; but you need to have the facility to accomplish that. Actually, I believed for a long time that all rattle can paints were simply crap--until we built a small low temperature oven to reliably work with Krylon Wrinkle paint without having to rely on the hot summer sun at mid day. We quickly learned that an overnight drying at around 110 degrees fahrenheight gave a factory applied level of adhesion and scratch resistance to all of those same old, previously unreliable, rattle can paints regardless of the season in southeastern Florida. OTOH, if you can not accomplish an over night "bake" of the paint you are using, you would be well advised to stay with products that can "cure" rather then "dry". (In case you are wondering: Krylon wrinkle paint could be removed with a thumbnail, even months after application, until we started baking it. We never used Rustoleum in the avionics shop, so I don't know how well the low temperature baking would have worked; but my previous experience with Rustoleum primer had been similar to the Krylon wrinkle--with the addition of a lingering odor--so my supposition is that a forced drying cycle would be effective there as well. Obviously, testing would be required before you could trust the result!) I hope this helps. Peter |
Stewart Headwind | Copperhead144 | Home Built | 2 | August 19th 08 12:58 AM |
Stewart Kissell | Frank Whiteley | Soaring | 10 | November 9th 07 12:19 AM |
Stewart Kissel | [email protected] | Soaring | 0 | October 29th 07 04:38 PM |
Stewart S-51 Mustang v-12 | pete83 | Home Built | 3 | March 17th 04 12:07 AM |
