SALTO canopy needed
Old November 5th 08, 10:43 PM posted to rec.aviation.soaring
Default SALTO canopy needed
Ok this is a very long shot...
Anyone got a Salto Canopy stashed away?
Prefer US location but will look at worldwide.
Thanks
Al
Old November 5th 08, 11:25 PM posted to rec.aviation.soaring
Bob Kuykendall
I can have tooling made and get you a first article for about what a
factory replacement will cost. Thereafter you can corner the market on
Salto canopies in this half of the globe.
Or if your standards are somewhat on the practical side a Todd's free-
blown replacement might suit you.
Thanks, Bob K.
Old November 6th 08, 02:38 PM posted to rec.aviation.soaring
JJ Sinclair
Looks kind'a Libellish to me, bet Ray Poquette could do you a modified
(heat and re-work the rear), Libelle canopy. He has a mold for it. I
have mounted one of them, looked good.
JJ
Thanks, Bob K.
Old November 7th 08, 05:00 AM posted to rec.aviation.soaring
Bob C[_2_]
I was recently looking at having a new canopy made for my Salto so I
wouldn't have to destroy the original to do the jet engine conversion.
The Salto is probably one of the hardest canopies to make. It is very
long and narrow, with reverse curves (like a potato chip) at both ends. I
finally gave up and cut the original.
Best bet would be to pull a mold from a good one and see if Todd or Ray
could make one. I seriously doubt if you could make a Libelle canopy
fit.
There are some reasonably good photos of mine before, during and after the
extensive modification at http://www.vertigoairshows.com/progress.html
You might be able to use some of the photos.
Also, there is a new person handling the Salto parts and maintenance. If
you're interested, e-mail me and I'll give you the info.
Bob
JJ
free-
Thanks, Bob K.
Old November 7th 08, 02:44 PM posted to rec.aviation.soaring
JJ Sinclair
Very interesting page, Bob. What's the thrust on that puppy and what
kind of temp did you read at the tail? The thought of installing a jet
just a few feet from the vertical fin leaves me nervous. The V tail
solves that problem.
Thanks for sharing,
JJ
fit.
Bob
JJ
free-
Thanks, Bob K.
Old November 7th 08, 06:07 PM posted to rec.aviation.soaring
Thanks for sharing,
JJ
The Salto is probably one of the hardest canopies to make. *It is very
long and narrow, with reverse curves (like a potato chip) at both ends. *I
could make one. *I seriously doubt if you could make a Libelle canopy
fit.
extensive modification athttp://www.vertigoairshows.com/progress.html
Also, there is a new person handling the Salto parts and maintenance. *If
Bob
JJ
free-
Thanks, Bob K.
Bob's project just increased dramatically the world wide demand for
Salto's
Al
Old November 13th 08, 12:50 AM posted to rec.aviation.soaring
soarbooks
On Nov 5, 4:43*pm, "
Thanks
Al
Some responders suggest that the Libelle canopy might be ...
persuaded ... to fit ...! but like Salto owner Bob Carlton I am quite
doubtful. I think the Libelle/Salto relationship has been a bit
overstated in some print publications over the last twenty or so
years, and that has led to to assumptions that they are twins; not
identical, but, nevertheless, fraternal twins. I am well familiar
with Libelles and Saltos (owning one) and find a remarkable number of
dis-similarities! They are more like siblings - related but very
different - than they are like fraternal twins, IMHO.
OK, I am metaphor-ed out....
Safe soaring to all,
Bob Wander
-End
Old November 21st 08, 03:45 AM posted to rec.aviation.soaring
Bob C[_2_]
Thrust is 225 lbs. Tail temps were below 140 on a 95 degree day. She's a
rocket ship for sure!
Bob
Thanks for sharing,
JJ
conversion.
The Salto is probably one of the hardest canopies to make. =A0It is
ver=
y
ends.=
=A0I
Ray
could make one. =A0I seriously doubt if you could make a Libelle
canopy
fit.
after
maintenance.
=A0If
Bob
modified
I
JJ
what
a
market
on
free-
Thanks, Bob K.
Salto's
Al
Salto Pilots.... [email protected] Soaring 1 July 9th 08 09:54 AM
Salto [email protected] Soaring 5 November 2nd 06 03:26 PM
Blanik L-13 Front canopy sheet needed Roy Bourgeois Soaring 1 June 2nd 06 12:31 AM
DART Canopy needed Ernie Soaring 2 January 17th 04 04:26 PM
Salto accident? Hank Nixon Soaring 0 July 23rd 03 02:36 PM
