How do you refuel an Air Force F35-B?
Old April 18th 04, 10:36 PM
Henry J Cobb
Default How do you refuel an Air Force F35-B?
USAF to Purchase Marines’ Vertical-Lift Fighter
http://www.jinsa.org/articles/articl...0,656,164,2407
Note the lift fan on the F-35B where the F-35A refueling-boom socket goes.
http://globalsecurity.org/military/s...craft/f-35.htm
So you need a KC-135R or KC-767 to refuel a F-35B, and the KC-767 can
only refuel one of these short ranged fighters at a time and only from a
safe distance to keep the airliner out of harm's way.
Perhaps USMC KC-130Js will go back to fill up from the AF KC-767s then
forwards to refuel AF F-35Bs? ;-)
-HJC
Old April 19th 04, 12:39 AM
Scott Ferrin
If they ever bought the KC-767 why couldn't they outfit it with two
under-wing refueling drouge systems? It's not like it's never been
done before.
-HJC
Old April 19th 04, 01:01 AM
Henry J Cobb
done before.
http://www.fas.org/man/crs/RL32056.pdf
The ORD requires, for example, that the KC-135's replacement be able
to refuel two aircraft simultaneously with the hose-and-drogue system.
The KC-767 variant being considered in this lease cannot satisfy this
requirement. It can only refuel one aircraft at a time with the
hose-and-drogue which considerably reduces, opponents say, its
operational capabilities.
http://www.afa.org/magazine/aug2003/0803tankers.asp
Though USAF wanted plumbing in the wings for wingtip probe-and-drogue
refueling, to lower cost, it dropped the requirement. The aircraft
will have both a boom-type refueling system and a probe-and-drogue,
both on the centerline.
http://www.airforce-technology.com/p...767/specs.html
Probe and drogue refuelling Wingpods and a centre-line hose
But the *-technology.com sites are often wrong.
Writing to them does help as they've changed the CIWS to RAM after I
notified them.
http://www.naval-technology.com/proj...d17/index.html
-HJC
Old April 19th 04, 12:46 AM
Brett
The KC-10 works - the KC-767 is still on hold.
and the KC-767 can
How many USAF fighters do you think get refueled at a time when an operator
guides the only boom on the tanker into the aircraft being refueled.
The only significant difference would be a 50% reduction in fuel transfer
rate.
Or add two extra hose and drogue systems to the wing of new build (or
modified/updated) tankers
-HJC
Old April 19th 04, 02:43 AM
Dweezil Dwarftosser
I would imagine that the USAF's only reason for purchase
of VTO F-35s would be forward-basing of them close to
the battle area, where in-flight refueling needs are
considerably lessened.
Old April 19th 04, 02:59 AM
Brett
"Dweezil Dwarftosser" wrote:
Henry J Cobb wrote:
USAF to Purchase Marines' Vertical-Lift Fighter
They are if your supply train can put a large quanties of fuel close to the
front line...
Old April 19th 04, 05:40 PM
Mark
And the ordnance, force protection personnel and equipment, aircraft support
equipment, food/water, etc etc etc....
The forward basing "feature" of the VSTOL is way oversold (IMHO)
Mark
"Brett" wrote in message
front line...
Old April 20th 04, 12:10 PM
Dweezil Dwarftosser
Of course - but I wonder if you realize that a standard
squadron mobility package (18.U.E., 24 U.E) in the tactical
forces was set up to contain all of the people, equipment,
and supplies for at least 30 days of autonomous operations?
(With the very low munitions capacity of today's much smaller
fighters, it should be even easier to transport the required
munitions - almost always the largest tonnage component of
the package.)
Besides - an FOL would likely use a very small number of
aircraft (4? 6 to include spares?) for a very short time,
measured in days - before moving on to a different location;
perhaps swapped out with fresh aircraft/personnel/supplies
from the more-rearward located base.)
Perhaps. It would be a new ballgame for the USAF, anyway.
Old April 20th 04, 08:56 PM
Mark
To clarify my point (slightly)...
If you need the JSF VSTOL capability to use a particular 'forward base', how
would you get the airlift into the proposed airfield? It's not so much the
forward basing per se.... to a 'conventional' NATO standard (8000 ft)
airstrip I'll sign on... send the conventional JSF. But to an airfield
where you need VSTOL to operate; the support logistics I see as being a
potential show stopper to effective operations.
wrt 'been done'....
Afghanistan/Desert Storm... very small numbers; very limited overall impact
on capability to successfully prosecute air war (just a subjective opinion)
Was is this forward basing done because it could only be done by Harriers,
or was it a matter that it so-happened to be Harriers. Was it an
operational imperative or an opportunity seized by USMC to "show their
stuff"?? I see a difference.
Mark
"Dweezil Dwarftosser" wrote in message
support
the package.)
Old April 20th 04, 10:57 AM
Paul J. Adam
"Mark" wrote in message
m...
support
Been done in action (Falklands, Desert Storm, Afghanistan) which is why it
remains popular. Transit time is a big part of your "numbers on station"
equation.
Paul J. Adam
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Air Force announces acquisition management reorganization Otis Willie Military Aviation 0 August 21st 03 09:16 PM
