effect of changed thrust line.
Old November 14th 08, 04:20 AM posted to rec.aviation.homebuilt
Default effect of changed thrust line.
How does a person determine what the proper height of an engine should
be when building an airplane? If a particular engine design mandates
the prop is 4 inches, say, lower than where it would be with the
engine originally installed, what effect will it have on handling, and
what changes in downthrust might be advised?
We are building a Pegazair, and my Corvair engine would need to have
the cowl higher than ideal to keep the crank centerline at the same
hight as say, an O200. Weight wize, the engines are just about
identical as equipped Have not determined the center of gravity of the
engine yet, to determine the overall length of the mount.
For those unfamiliar with the plane it is a highwing STOL 2 placer
roughly the same size as a Cessna 150 (150 sq ft wing,33 ft wingspan,
Old November 14th 08, 05:06 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Doubtful that you would ever notice a difference in a 4" change, but if it
originally has downthrust, and you move the prop lower, you would take
downthrust out, but not much. 1/2 degree, perhaps? Hardly enough to be
able to change, I would think.
Also, don't forget the use of washers. (shims) With it being experimental,
that is one of the fun things to "have to" figure out. Dang, hours flying
around, doing tests! What a way to spend your time, right? g
Tough life, but someone's got to do it! g
Old November 14th 08, 05:25 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Dang, it, I got it backwards. It would theoretically need downthrust
_added_.
Think about it. A seaplane with an engine up on a pylon has up thrust, so
when you add power, that the nose does not go down as much.
Wit the center of drag higher than the engine, you have down thrust so added
power does not lift the nose as much, so going higher, take down out; lower,
add down.
Old November 14th 08, 05:28 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Good to see you around, again. :-) Howz the project going?
Did you have a web page or blog with your project on it? I lost everything
with a total computer melt-down a while back.
Old November 14th 08, 07:26 AM posted to rec.aviation.homebuilt
Alan Baker
_added_.
add down.
Read this. Read it again and again until you get it:
Don't take moments about anything other than the centre of mass.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
Old November 14th 08, 01:05 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
_added_.
add down.
Why?
I mean specifically, how else would you even FIND the center of mass?
What difference does it make whether it's center of mass or center of
the axles?
Or leading edge of the wing?
Or a point 1" in front of the tip of the spinner???
The numbers for the moments will certaintly look different, but they
all relate to the same spot on the aircraft...
Richard
(remove the X to email)
Old November 14th 08, 01:35 PM posted to rec.aviation.homebuilt
Alan Baker
_added_.
added
lower,
add down.
Why?
the axles?
First: yes, any *fixed* point will do, which the centre of drag is not.
Second, the math is easiest when you pick the point that is actually the
one about which the body will rotate.
Alan Baker
Old November 14th 08, 01:56 PM posted to rec.aviation.homebuilt
_added_.
added
lower,
add down.
Why?
the axles?
Some people find it "easiest" to avoid the negative numners and use the tip
of the spinner
Richard
Old November 14th 08, 02:18 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
suck it and see.
your elevator should have enough authority to control the resulting
couple.
you should experience some upthrust but tweaking back the throttle
should control it.
your question in the first line....
take the centre of mass as the pivot point.
you have 4 force couples.
lift vs moment arm.
elevator down thrust vs moment arm
wing drag vs moment arm
thrust vs moment arm.
they will summate to zero in equilibrium but
you probably wont know any of the values o those forces.
alan baker will probably give a guestimate.
suck it and see.
I think you'll need the same side thrust but a little more down thrust
as the cessna 150..
Stealth Pilot
Old November 14th 08, 04:11 PM posted to rec.aviation.homebuilt
Alan Baker
suck it and see.
couple.
should control it.
lift vs moment arm.
suck it and see.
as the cessna 150..
Stealth Pilot
The math isn't all that hard.
Assuming the designed thrust line goes relatively close to the centre of
mass, then if you want to keep the torque created by thrust close to the
same, you need to change the angle of the engine by arctan(h/l), where h
is the amount you're moving the engine up or down and l is the distance
between the propellor and the centre of mass.
I suck at ASCII art, but:
-----T' (new thrust line)
h |
-----T--(old thrust line)--------------------------------C
l (CoM)
h/l is equal to the tangent of the angle TCT'
If the thrust line is not aligned with the CoM to begin with, then
situation isn't quite as simple, but for small misalignments the effect
is small and for larger misalignments the overall change in torques is
smaller in comparison.
Draw few diagrams of the situation and you'll see what I mean. I'm not
even going to try to draw that situation here. Basically, if the thrust
line was already above the CoM and you move it up, then the change is
smaller than the arctangent of h/l and if it was below the CoM the
change is a little greater than the arctangent.
Alan Baker
thrust line for engine and not mounting engine on this thrust line tommyann Home Built 8 December 15th 06 04:31 PM
Has something changed [email protected] Soaring 10 May 3rd 05 09:34 PM
High thrust line on canard design? Shin Gou Home Built 4 March 5th 05 04:06 AM
Getting students to line up with the center line BoDEAN Piloting 27 April 21st 04 12:23 PM
I want to tell you something that has changed my life! C J Campbell Owning 11 January 30th 04 12:34 AM
