My First Homebuilt
Old December 11th 08, 12:18 AM
choptopjim choptopjim is offline
Junior Member
First recorded activity by AviationBanter: Dec 2008
Default My First Homebuilt
I bought a started Homebuilt project from a Guy who passed on before finishing the build. His work is Top Notch and I don't think I will have any trouble getting his work accepted when I have the EAA people inspect the project. I believe that getting someone to look things over now is the best way to start out, then I can start my own documentation from this point on because I am going for the Experimental Certificate instead of the Part 103 route. After reading all I could find on the Banty, I do not think a 28 HP engine will be enough power and getting in under the 254 lb weight limit would be tough, because I will be using solid spars instead of the built up type shown on the plans. Going to modify the landing gear also, whats on the plans looks weak. My Fuse is 90% built and the Tail feathers are complete except for Hinging and covering and all the Ribs are built up and ready to slide onto the spar. This is my first attempt at building an airplane and any comments about my plan of attack would be welcome, I am going to need all the help I can get. Does anyone have any suggestions about which Powerplant to use or any Wing Mods for better strength or Safety concerns. I have started sanding on the Fuse as the Spar varnish has started to show some age and needs freshining up. Any Comments?
Fox Homebuilt [email protected] Home Built 0 December 3rd 05 02:58 AM
New Engine on New homebuilt David Koehler Home Built 19 August 14th 05 10:30 PM
Big guy considering a homebuilt... Rutger Home Built 3 August 11th 04 06:57 PM
Can anyone ID this homebuilt? JLB Home Built 9 April 29th 04 09:01 PM
rec.aviation.homebuilt Byron J. Covey Home Built 0 March 7th 04 05:11 PM
