North-Up versus Direction-Up?
Old December 17th 08, 02:09 AM posted to rec.aviation.soaring
ContestID67
Default North-Up versus Direction-Up?
It is winter here and the only soaring we are doing in Chicago is in
the hangar . During an energetic discussion on the pros and cons of
various soaring programs, I mentioned I fly "Direction-Up", rather
than "North-Up".
WHOA! You would have thought that I had said I was going to give up
soaring to fly helicopters by the dirty looks that I received.
Now, to be fair, with every GPS device I use (car, boat, GA), I
*ALWAYS* orient the map as north-up, and prefer it overall...except,
that is, when soaring. I started using north-up at first, but soon
found that a direction-up display was much better in letting me
anticipate the timing of rolling out of a thermal and heading towards
the next turn point. Attempting to coordinate the rotating glider
icon on a stationary north-up map, with the view outside and/or
compass, all while centering a thermal, is a bit like patting my head
and rubbing my stomach at the same time. Maybe this is unique to a
thermal-only soaring climate. NOTE: I am not directionally
challanged.
Anyway, I wondered what others use relative to the type of soaring
they do.
Thanks, John
Old December 17th 08, 03:04 AM posted to rec.aviation.soaring
Tuno
Not sure what you mean by "direction-up". (Wherever my nose is
pointed, that's my direction, I figure.)
I use "goal up" when I have a turnpoint dialed in, "north up"
otherwise.
~ted/2NO
Old December 17th 08, 03:15 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
I agree with the direction up. I AM directionally challenged on the ground
and when I enter an building I no longer remember after one turn which way
north is.
If you get any more dirty looks, ask if they always hold their sectional
north up or if they rotate it to follow their course line. It can be done
both ways, but course line up is much easier.
than "North-Up".
challanged.
they do.
Thanks, John
Old December 17th 08, 03:22 AM posted to rec.aviation.soaring
Ray[_4_]
While flying, especially in thermals, I prefer "heads up".
W7
than "North-Up".
challanged.
they do.
Thanks, John
Old December 17th 08, 03:43 AM posted to rec.aviation.soaring
MarkHawke7
I am one of the developers of SoarPilot which supports, north up,
track/direction up and course-up and I have pondered this many times.
I believe a given person's preference is simply that...personal. I'm
not a neuro-scientist in anyway, but I think a given person's
preference is mostly driven by how they process spacial and/or
geospacial representations in general and by what they have been
taught to use. Do you prefer to have what you see outside the glider
match what you are seeing on the screen OR do you prefer to mentally
convert and correlate what you are seeing outside with what you would
see on a North up map? From elementary school we are taught to use
and read north-up maps. So we become VERY comfortable with that way
of looking and processing geospacial information. As an example of
what I mean, I have seen a large world wall map in the typical, oval,
equidistant-cylindrical representation. It is normal in every respect
for one....it has the world depicted South UP. And when you look at
it, it immediately seems VERY, VERY wrong? But if you think about it,
it is no more incorrect a representation than a North up map. It only
seems wrong because it's not they way we're used to seeing it.
Later!
-Mark
PS. I like track up best as well.
W7
than "North-Up".
that is, when soaring. * I started using north-up at first, but soon
the next turn point. *Attempting to coordinate the rotating glider
and rubbing my stomach at the same time. *Maybe this is unique to a
thermal-only soaring climate. * *NOTE: I am not directionally
challanged.
they do.
Thanks, John
Old December 17th 08, 03:53 AM posted to rec.aviation.soaring
I taught map and compass skills for the army for many years. We
always plotted our route in North Up, but then used it oriented to
track when we were out in the field -- much easier to co-ordinate
objects on the ground with objects on the map this way, we looked in
the correct relative direction.
Old December 17th 08, 04:29 AM posted to rec.aviation.soaring
I'm a happy use of SoarPilot. On course I use it in "track up" mode
because that gives me
the most screen space along my path of flight. I'm not interested in
what's 90 degrees off
the course line (not usually anyway). While thermalling I'm not
looking at the PDA much;
the color coding that SP does for the lift is usually too far behind
what I'm doing, and it's too
hard to see. All I look at is the average lift calculation so I know
when the lift is petering out
(I leave when the 20sec average drops below that bottom-top average,
which usually means
the thermal is down to 80% of its best). Well, I do look at the
course line, but again
the depiction is usually a couple seconds out of date so it's easy to
overshoot the
course line if I depend on the PDA. Instead, I try to pick out
landmarks in the direction
I want to go so I stay oriented, and then pick out lift sources in the
last several times around
in the thermal. As far as looking at the map (I refer to that too) I
use that both "course-up"
and "north-up" depending on whether I want to find landmarks or read
the text printed on
the map.
-- Matt
PS that north-up cylindrical projection we all had in our schoolrooms
as kids had another
feature -- the Northern Hemisphere is depicted in a larger scale than
the Southern! They
did it that way since most of the landmass is in the north. The next
time you see one take
note of where the equator is. That "upside-down" map you saw, Mark,
places the equator
back in the middle so the sizes won't match what you remember even if
you look at it
in your familiar orientation.
I believe a given person's preference is simply that...personal. *I'm
taught to use. *Do you prefer to have what you see outside the glider
see on a North up map? *From elementary school we are taught to use
and read north-up maps. *So we become VERY comfortable with that way
of looking and processing geospacial information. *As an example of
equidistant-cylindrical representation. *It is normal in every respect
for one....it has the world depicted South UP. *And when you look at
it, it immediately seems VERY, VERY wrong? *But if you think about it,
it is no more incorrect a representation than a North up map. *It only
Later!
-Mark
PS. *I like track up best as well.
W7
than "North-Up".
challanged.
they do.
Thanks, John
Old December 17th 08, 06:52 AM posted to rec.aviation.soaring
On Dec 16, 8:29*pm, wrote:
I'm a happy use of SoarPilot. *On course I use it in "track up" mode
the most screen space along my path of flight. *I'm not interested in
the course line (not usually anyway). *While thermalling I'm not
hard to see. *All I look at is the average lift calculation so I know
which usually means
the thermal is down to 80% of its best). *Well, I do look at the
overshoot the
course line if I depend on the PDA. *Instead, I try to pick out
in the thermal. *As far as looking at the map (I refer to that too) I
the text printed on
the map.
-- Matt
Track up for me - makes it easier to align what's on the map with the
view out the window, particularly for course deviations, finding
alternates, picking MAT turnpoints, etc.
9B
Old December 17th 08, 11:52 AM posted to rec.aviation.soaring
DRN
than "North-Up".
challanged.
they do.
Thanks, John
Actually, the question is a bit more complicated then you've
posed, as there are more options:
- track up
- North up
- nose up
Nose up is not what precedes a stall ;-)
It's when the map is rotated to match what you
see over the nose, adjusting your track to take
account of the wind. Also used in ILEC SN10
to rotate the wind arrow so it matches the view
outside. The advantage is substantial when
you're flying with a crosswind.
ILEC SN10 pilots can choose North or Nose Up
for the map (wind arrow is always rotated Nose
Up).
Hope that helps,
Old December 17th 08, 02:18 PM posted to rec.aviation.soaring
kirk.stant
Heading (Nose) up while flying - allows orientation with real world
(really important when winds are strong!). But this requires a good
Track display on the map; I have a nice track line on my mSeeYou map
that I can use to see how my wind corrected track compares with my
desired course line. I just adjust my heading to make sure my actual
track is taking me to the next turnpoint to avoid "homing". Also
matches the map on my SN10.
North up when creating a task - somewhat easier to see "big picture",
but not useful when actually flying, IMO (other than possibly when
thermalling - tried it but still prefer Heading up).
Kirk
66
Traffic with direction Dave Products 14 August 10th 05 06:44 AM
more bitching about the IFR written - CDI left/right versus north/south/etc G. Sylvester Instrument Flight Rules 58 January 12th 05 02:32 AM
"zero" versus "oscar" versus "sierra" Ron Garret Piloting 30 December 20th 04 08:49 AM
Dr. Jack's Wind Direction rjciii Soaring 14 October 5th 03 05:37 AM
Wind Direction --=JJay=-- Soaring 2 September 27th 03 07:18 PM
