the items in question are the tailfeathers of a 4 seat radial engined Yak. (yak 18T I think it is) we're not sure whether we are following original factory work or someones abortion. the rib caps have a section like ----v---- in the centre of the v there is a hole every inch. it appears that instead of following english/american practise of tying the ribstitch around the rib from top to bottom and tying off each loop individually the ruskies have taken two adjoining holes and stitched button style around and around, then moved to the next pair and stitched around and around and so on. the top stitching is only along the top rib cap. the bottom rib stitching is only along the bottom rib cap. are we looking at factory original stitching or is this something that subsequent refabric work has done? if it is the original ruskie system it produces a very neat rib treatment. Stealth Pilot |
"Stealth Pilot" wrote in message
... the items in question are the tailfeathers of a 4 seat radial engined Yak. (yak 18T I think it is) we're not sure whether we are following original factory work or someones abortion. the rib caps have a section like ----v---- in the centre of the v there is a hole every inch. it appears that instead of following english/american practise of tying the ribstitch around the rib from top to bottom and tying off each loop individually the ruskies have taken two adjoining holes and stitched button style around and around, then moved to the next pair and stitched around and around and so on. the top stitching is only along the top rib cap. the bottom rib stitching is only along the bottom rib cap. are we looking at factory original stitching or is this something that subsequent refabric work has done? if it is the original ruskie system it produces a very neat rib treatment. Stealth Pilot I admit that my personal knowledge of rib stitching is essentially nil, but: 1) what you describe could be done easily with a "sail needle" 2) it would give the "benefit" of a clear area and no risk of fouling, and 3) as Veeduber pointed out in an adjacent thread, the loads are small. So, I don't know either, but it could very well be a factory solution:. There was a two seat YAK in the local EAA chapter, so I'll try to ask. Peter |
Might that be a field-replacement for the sort of wire clips that
Cessna used on 120/140? http://www.aircraftspruce.com/catalo.../cessnawfc.php Thanks, Bob K. On Dec 30, 2:29*am, Stealth Pilot wrote: the items in question are the tailfeathers of a 4 seat radial engined Yak. (yak 18T I think it is) we're not sure whether we are following original factory work or someones abortion. the rib caps have a section like ----v---- in the centre of the v there is a hole every inch. it appears that instead of following english/american practise of tying the ribstitch around the rib from top to bottom and tying off each loop individually the ruskies have taken two adjoining holes and stitched button style around and around, then moved to the next pair and stitched around and around and so on. the top stitching is only along the top rib cap. the bottom rib stitching is only along the bottom rib cap. are we looking at factory original stitching or is this something that subsequent refabric work has done? if it is the original ruskie system it produces a very neat rib treatment. Stealth Pilot |
"Stealth Pilot" wrote in message ... the items in question are the tailfeathers of a 4 seat radial engined Yak. (yak 18T I think it is) we're not sure whether we are following original factory work or someones abortion. the rib caps have a section like ----v---- in the centre of the v there is a hole every inch. it appears that instead of following english/american practise of tying the ribstitch around the rib from top to bottom and tying off each loop individually the ruskies have taken two adjoining holes and stitched button style around and around, then moved to the next pair and stitched around and around and so on. the top stitching is only along the top rib cap. the bottom rib stitching is only along the bottom rib cap. are we looking at factory original stitching or is this something that subsequent refabric work has done? if it is the original ruskie system it produces a very neat rib treatment. Stealth Pilot Wasn't there some aircraft of the pre-war era that used screws into the rib-caps instead of stitching? Flash |
Wasn't there some aircraft of the pre-war era that used screws into the rib-caps instead of stitching? Aeronca 7AC, 11AC and Ercoupe are two that I've recovered that use screws. it can be a fun job---a nice Summer evening, a drop light under the wing to show up the holes in the ribs, An ice pick to punch the holes, a six pack of beer------------ Cheers: Paul N1431A KSDM |
On Dec 31, 10:18*am, "Tri-Pacer" no wrote:
it can be a fun job---a nice Summer evening, a drop light under the wing to show up the holes in the ribs, An ice pick to punch the holes, a six pack of beer------------------------------------------------------------------------------------------------------------ It could also be a hell of a job. Dob about a dozen screws with paint remover, use a needle-sharp scriber to pry the softened dope out of the screw-head, easy if they're slotted, pure hell if they've used Phillips, Scott or Cross (ie, other forms of the Phillips patent). Better done at night than during the day, however. But nights, you've also got to deal with mosquitoes, and moths the size of sparrows. When Bob K mentioned it (see above) that was the first thing I thought of -- those aluminum strips installed with those low-profile Phillip's head screws. Funny thing... you'll often find the clipped or screwed fabric fastener systems on airplanes that didn't come that way from the factory. I've often wondered about that, since it tends to indicate a revision of the wing, going to a metal rib with the newer method of securing the fabric. There must be an STC for screwed-straps on several of the DC's. Least ways, I've seen it on DC-3's and DC-4's. (May have been for Razor back...) Vietnam, we used beer-can aluminum and gray RTV, plus tying it off to a matching piece on the other side. Those were all razorback but the Air Force didn't have anyone in-country qualified to do it -- they were shipping their rudders and elevators all the way back to Long Beach, when all they needed (most of the time) was a simple repair. -R.S.Hoover |
| Thread Tools | |
| Display Modes | |
| Rib Stitching: Ho Ho Ho :-) | [email protected] | Home Built | 5 | December 29th 08 02:24 AM |
| RAF Plays cat and mouse with Russians (link) | heavyhorses | Aviation Photos | 0 | May 11th 07 09:41 AM |
| Rib stitching vs glueing | [email protected] | Home Built | 30 | October 19th 05 04:25 AM |
| Russians to Militarize Schools | Grantland | Military Aviation | 9 | February 15th 04 06:03 AM |
| supersonic russians | flybywire | Military Aviation | 5 | December 22nd 03 05:40 PM |
