Radio Noise
Old January 8th 09, 08:44 PM posted to rec.aviation.homebuilt
Bob
Default Radio Noise
Com Icom A-6 handheld connected only to headset, NO CONNECTION TO A/C
ELECTRICAL. Static noise and flickering RX symbol on handheld (no
voice being received)so distractiing its makes use unbearable. No
static during actual voice reception-tower reports clear,good, no
noise voice. Outside of a/c facing prop or tail (no noise)-move in
circle about a/c noise develops. Inside a/c noise at all times except
during actual voice reception. The following have NO affect: tried
different radio,headset, partchcords-disconnected alternator
belt,field lead-put condensor for noise trap on regulator,coil,
distributor-on/off of elec T/B(has in-line filter),trim
tab,intercom,strobe,elec tach to - coil post,all electrical
connections,wires,terminal strips verified good-only other electrical
are the amp/vot meter connections. Noise does not occur when radio/
headset combo used in other a/c. Noise cancelled out at squelch level
20 and high volume. 12 years building, FAA certified, l year so far
chasing "BUGS" and hopefully last item to correct so I CAN FLY!
P LEASE HELP IF YOU WOULD
Thank You,
Old January 8th 09, 10:48 PM posted to rec.aviation.homebuilt
RST Engineering
Default Radio Noise
Sounds suspiciously like ignition noise to me. You might want to tell us
what kind of aerocraft this is.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
"Bob" wrote in message
Thank You,
Old January 9th 09, 01:22 AM posted to rec.aviation.homebuilt
Bob
Default Radio Noise
voice being received)so distractiing its makes use unbearable. *No
Thank You,
This is a KR2S with a Corvair 2700cc/164cid engine converted per
William Wynne Manual and uses a distributor/coil and a JD Dynamo w/
regulator.
Old January 9th 09, 01:26 AM posted to rec.aviation.homebuilt
Bob
Default Radio Noise
Thank You,
regulator.- Hide quoted text -
- Show quoted text -
Using Moroso Blue Max plug wires.
Old January 9th 09, 04:18 PM posted to rec.aviation.homebuilt
Default Radio Noise
Thank You,
Unshielded ignition leads. Unshielded tach lead, unshielded
distributor wiring to the switch. No wonder there's lots of noise.
Every spark impulse produces a broadband radio signal.
Dan
Old January 10th 09, 10:32 PM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
Default Radio Noise
voice being received)so distractiing its makes use unbearable...
I have the A24 (same radio as yours except with VOR added). I
eliminated the noise by turning on the radios "ANL" (Automatic Noise
Limiter) function, and switching to resistor spark plugs.
-Dana
I don't suffer from insanity. I enjoy every minute of it.
Old January 11th 09, 07:11 PM posted to rec.aviation.homebuilt
RST Engineering
Default Radio Noise
My diagosis from afar is ignition noise. No two ways about it. You MIGHT
be able to get away with resistor wire or resistor plugs, but talk to your
local EAA tech counselor about shielded ignition, shielded this, shielded
that.
An automotive engine is one of the best broadband noise sources known to
man.
regulator.
wiring second radio and noise flps_74 Owning 3 November 4th 08 10:43 PM
radio noise et Home Built 4 September 30th 08 06:43 PM
Radio ignition noise. [email protected] Home Built 6 August 17th 07 06:15 PM
Radio ignition noise [email protected] Home Built 0 August 16th 07 04:46 PM
Static/Squelch Noise in Radio Kensandyeggo Home Built 2 April 13th 06 10:00 PM
