Before Help Arrived
Old January 16th 09, 02:24 PM posted to alt.binaries.pictures.aviation
Mitchell Holman Mitchell Holman is offline
Banned
First recorded activity by AviationBanter: Nov 2006
Default Before Help Arrived
Down in the Hudson
Old January 16th 09, 07:44 PM posted to alt.binaries.pictures.aviation
Herman
"Mitchell Holman" schreef in bericht
Down in the Hudson
Remarkable demonstration of airmanship by that pilot.
Do you think anyone would have moving pictures of the actual forced landing?
Regards,
Herman
Old January 16th 09, 11:42 PM posted to alt.binaries.pictures.aviation
Banned
"Herman" wrote in
b.home.nl:
Down in the Hudson
landing?
Regards,
Herman
The whole thing happened pretty quickly, I doubt
there is any footage of the actual landing.
Old January 17th 09, 01:17 AM posted to alt.binaries.pictures.aviation
Glenn[_2_]
So while everyone was able to succesfully get off, why were there no
Liferafts ?
"Mitchell Holman" wrote in message
Down in the Hudson
Old January 17th 09, 01:46 AM posted to alt.binaries.pictures.aviation
Robert Moore
Liferafts ?
Not required......
FAR 1:
Extended over-water operation means—
(1) With respect to aircraft other than helicopters, an operation over
water at a horizontal distance of more than 50 nautical miles from the
nearest shoreline;
Section 121.339: Emergency equipment for extended over-water operations.
No person may operate an airplane in extended overwater operations
without having on the airplane the following equipment:
(1) A life preserver equipped with an approved survivor locator light,
for each occupant of the airplane.
(2) Enough life rafts (each equipped with an approved survivor locator
light) of a rated capacity and buoyancy to accommodate the occupants of
the airplane. Unless excess rafts of enough capacity are provided, the
buoyancy and seating capacity beyond the rated capacity of the rafts
must accommodate all occupants of the airplane in the event of a loss of
one raft of the largest rated capacity.
Section 121.340: Emergency flotation means.
(a) Except as provided in paragraph (b) of this section, no person may
operate an airplane in any overwater operation unless it is equipped
with life preservers in accordance with §121.339(a)(1) or with an
approved flotation means for each occupant. This means must be within
easy reach of each seated occupant and must be readily removable from
the airplane.
(b) Upon application by the air carrier or commercial operator, the
Administrator may approve the operation of an airplane over water
without the life preservers or flotation means required by paragraph (a)
of this section, if the air carrier or commercial operator shows that
the water over which the airplane is to be operated is not of such size
and depth that life preservers or flotation means would be required for
the survival of its occupants in the event the flight terminates in that
water
Old January 17th 09, 05:44 AM posted to alt.binaries.pictures.aviation
Avsec
Thanks for the posting Mitchell. A good example when a picture is better
than a thousand words. What I find interesting that it occurred without a
single boat in the proximately of the ditching which could have been
fortunate under the circumstances.
Cheers,
Avsec
Old January 17th 09, 05:45 AM posted to alt.binaries.pictures.aviation
Orval Fairbairn[_2_]
Liferafts ?
From the pictures, it appears that they used the slides as rafts --
standard practice.
Remove _'s from email address to talk to me.
Old January 17th 09, 08:06 AM posted to alt.binaries.pictures.aviation
Glenn[_2_]
Ok, so there is no provision provided for over land water crashes in sub
zero temperatures.
I guess we got lucky that there was a lot of vessels around that got to them
quickly.
"Robert Moore" wrote in message
5.247...
Liferafts ?
Not required......
FAR 1:
Extended over-water operation means-
nearest shoreline;
the airplane.
water
Old January 17th 09, 01:55 PM posted to alt.binaries.pictures.aviation
Banned
"Avsec" wrote in news:49716225$0$26849$afc38c87
@news.optusnet.com.au:
Cheers,
Avsec
The fact that the pilot was also trained in gliders helped.
Old January 17th 09, 08:46 PM posted to alt.binaries.pictures.aviation
nockers
On Sat, 17 Jan 2009 06:55:32 -0600, Mitchell Holman
Cheers,
Avsec
MSNBC has some fottage of the touchdown
http://www.msnbc.msn.com/id/28688215?gt1=43001
The ethanol nightmare has arrived! Al[_2_] Piloting 210 April 24th 08 04:27 PM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Military Aviation 1 May 27th 04 10:42 PM
first P-3C CUP Orion arrived at Valkenburg Marco P.J. Borst Naval Aviation 1 May 27th 04 10:42 PM
(long) WxWorx arrived... Tom S. Instrument Flight Rules 1 September 10th 03 01:37 AM
(long) WxWorx arrived... Dan Luke Piloting 0 September 10th 03 01:37 AM
