Want to build a REAL engine?
Old January 17th 09, 05:14 PM posted to rec.aviation.homebuilt
bildan
Default Want to build a REAL engine?
I've been kicking this idea around with some mechanical engineers for
a couple of years.
Motorcycle in-line fours are state of the art high performance engines
unencumbered by smog controls. They get more than 100HP per liter
with some at 140 HP/liter. Of course, they rev like a dentist's
drill.
More importantly, the cylinder/head assembly just bolts to the
crankcase. Now, think of 7 or 9 of these in-line water cooled 4-cyl
blocks arranged radially around a common crankcase.
To make it work, you have to make the case, crank and new master/
articulating connecting rods. You'd also need a gear case to drive
the cam chains. Finally, you'd need some serious gear reduction
(~7:1) planetary gear set in the nose case. I'd also use an aircraft-
type fuel injection system instead of carbs.
If it worked, in the case of 9 cylinder blocks, you'd have a 36
cylinder, 500 pound, 30" diameter, 1000HP+ liquid cooled radial
reminiscent of a half scale Lycoming XR7755.
Now build a slick little carbon composite airplane around the monster
and take it to Reno. I'll bet the sound alone would wow the crowds.
Soooo, what is the best plane to build around a corvair engine? Lou Home Built 21 November 11th 06 01:56 AM
Real Time to build an RV10 [email protected] Home Built 13 October 31st 05 03:20 AM
My 9th Wedding Anniversary Trip, To Newport, OR Carb Ice & Real Engine Out "Long" NW_PILOT Piloting 32 June 29th 04 12:45 AM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 04:29 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
