anyone ever re-packed the whell bearings on a Komet trailer?
I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan |
On Feb 1, 11:09*am, Dan wrote:
anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan There should be nothing difficult in this. There are good sources of info online, one of the best is this boat trailer info at http://www.sailingtexas.com/Movies/T...rbearings.html I don't know if or when Komet switched to used sealed wheel bearings like Cobra. If my trailer did not have sealed wheel bearings, personally I'd be doing this annually, especially if stored in high moisture/coastal areas. And check out brakes, suspension, etc. carefully at the same time. Rex Mayes gave a great talk on glider trailer maintenance a few weeks ago. We need to get Rex or John Murray or others who give these talks on video some time. Darryl |
On Feb 1, 12:11*pm, Darryl Ramm wrote:
On Feb 1, 11:09*am, Dan wrote: anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan There should be nothing difficult in this. There are good sources of info online, one of the best is this boat trailer info athttp://www.sailingtexas.com/Movies/TrailerBearings/trailerbearings.html I don't know if or when Komet switched to used sealed wheel bearings like Cobra. If my trailer did not have sealed wheel bearings, personally I'd be doing this annually, especially if stored in high moisture/coastal areas. And check out brakes, suspension, etc. carefully at the same time. Rex Mayes gave a great talk on glider trailer maintenance a few weeks ago. We need to get Rex or John Murray or others who give these talks on video some time. Darryl thanks Daryl; That video was very helpful. I really appreciate it. Take care, Dan |
On Feb 1, 2:09*pm, Dan wrote:
anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan Coming in a little late, but... Nothing to it. I did mine several times when I owned my old (circa 1981) Komet. It was about an hour to maybe an hour and a half to finish both sides. Pull the wheel. Pry off the cap. Unpin the castelated nut. Loosen nut. Pull the hub. Was there something specific that got you wondering? Regards, Erik Mann LS8-18 P3 |
On Feb 2, 6:05*am, Papa3 wrote:
On Feb 1, 2:09*pm, Dan wrote: anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan Coming in a little late, but... Nothing to it. *I did mine several times when I owned my old (circa 1981) Komet. * It was about an hour to maybe an hour and a half to finish both sides. *Pull the wheel. *Pry off the cap. * Unpin the castelated nut. *Loosen nut. * Pull the hub. Was there something specific that got you wondering? Regards, Erik Mann LS8-18 P3 I wasn't sure if all Komet trailers had sealed bearings or not, guess I'll have to look. I don't know the vintage of my trailer. The video Daryl posted is excellent. I'll check it out this weekend Thanks, Dan |
On Feb 2, 8:05*am, Papa3 wrote:
On Feb 1, 2:09*pm, Dan wrote: anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan Coming in a little late, but... Nothing to it. *I did mine several times when I owned my old (circa 1981) Komet. * It was about an hour to maybe an hour and a half to finish both sides. *Pull the wheel. *Pry off the cap. * Unpin the castelated nut. *Loosen nut. * Pull the hub. Was there something specific that got you wondering? Regards, Erik Mann LS8-18 P3 Aren't you going to need a replacement inner seal? In order to get the bearing out of the hub, the seal needs to get pulled. I don't know about you, but I've never been able to do that without damaging it. |
On Feb 2, 4:08*pm, wrote:
On Feb 2, 8:05*am, Papa3 wrote: On Feb 1, 2:09*pm, Dan wrote: anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan Coming in a little late, but... Nothing to it. *I did mine several times when I owned my old (circa 1981) Komet. * It was about an hour to maybe an hour and a half to finish both sides. *Pull the wheel. *Pry off the cap. * Unpin the castelated nut. *Loosen nut. * Pull the hub. Was there something specific that got you wondering? Regards, Erik Mann LS8-18 P3 Aren't you going to need a replacement inner seal? In order to get the bearing out of the hub, the seal needs to get pulled. I don't know about you, but I've never been able to do that without damaging it.- Hide quoted text - - Show quoted text - IIRC, I was able to punch out the seal using a custom built "bearing removal impact application device"; i.e. I turned a piece of scrap to the right diameter to fit the inner bearing race and apply force uniformly. I could be confusing this one with a Shroeder that I also worked on... I'll have to go look at my old notebook where I wrote this sort of stuff down. |
On Feb 2, 6:25*pm, Papa3 wrote:
On Feb 2, 4:08*pm, wrote: On Feb 2, 8:05*am, Papa3 wrote: On Feb 1, 2:09*pm, Dan wrote: anyone ever re-packed the whell bearings on a Komet trailer? I don't know when this was last done on my trailer but I'm thinking it's something I should do this winter. Dan Coming in a little late, but... Nothing to it. *I did mine several times when I owned my old (circa 1981) Komet. * It was about an hour to maybe an hour and a half to finish both sides. *Pull the wheel. *Pry off the cap. * Unpin the castelated nut. *Loosen nut. * Pull the hub. Was there something specific that got you wondering? Regards, Erik Mann LS8-18 P3 Aren't you going to need a replacement inner seal? In order to get the bearing out of the hub, the seal needs to get pulled. I don't know about you, but I've never been able to do that without damaging it.- Hide quoted text - - Show quoted text - IIRC, I was able to punch out the seal using a custom built "bearing removal impact application device"; i.e. I turned a piece of scrap to the right diameter to fit the inner bearing race and apply force uniformly. * I could be confusing this one with a Shroeder that I also worked on... *I'll have to go look at my old notebook where I wrote this sort of stuff down.- Hide quoted text - - Show quoted text - Thanks to all for the help. I re-packed the bearings and put new rubber on the trailer this weekend. The bearings were not the sealed type so it was good to check them and re-grease them. All set to go for many more miles. Dan Rihn WO |
Komet III wheel info | Gary Emerson | Soaring | 2 | February 4th 09 03:14 AM |
Old Komet Trailer | thermalrider | Soaring | 7 | October 11th 08 04:13 PM |
Q about trailer wheel bearings | Ken Ward | Soaring | 1 | September 15th 06 02:40 AM |
Komet trailer strut | John Shelton | Soaring | 5 | November 15th 03 05:04 PM |
E2-C wheel bearings needed | CaptAro | Restoration | 1 | July 19th 03 04:32 AM |
