AR3201 Harness?
Old March 6th 09, 12:00 PM posted to rec.aviation.soaring
noel.wade
Default AR3201 Harness?
Hi All,
I have an old Becker AR3201 that's working fine; but I managed to
slice a few of the wires in the harness while re-wiring my glider this
month (I decided it was time to get the rat's nest of PVC wire and old
tube-type fuses out of the cockpit). A blade-type fuse on the
battery, Anderson power-pole connectors, and a few circuit breakers
all connected with Tefzel wire make for a much cleaner setup!
Anyways - Since the model 3201 has been discontinued, I haven't been
able to find any source of pre-fab wiring harnesses (at least, not
online). I _could_ repair the harness myself with some careful
soldering, but a new harness would be a lot nicer (especially since I
have a gooseneck mic, a stick-mounted PTT switch, and the Becker audio
box mounted aft of the spar carrythrough area... so there are a lot of
wires to be hooked up properly and deliver a clean signal).
Any thoughts or suggestions?
Thanks! Take care,
--Noel
looking for Hooker harness Al MacDonald Home Built 0 July 12th 08 04:54 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 07:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 02:38 PM
S-H safety harness (V2C) [email protected] Soaring 20 April 28th 06 09:54 AM
Harness Nolaminar Restoration 2 December 25th 03 04:04 PM
