Batteries for Schleicher fin compartment
Old March 12th 09, 05:36 PM posted to rec.aviation.soaring
Tuno
Default Batteries for Schleicher fin compartment
It looks like the Power-Sonic PS-1229 is the correct size but I'd like
to know what others might be tried and tested.
Looking to start using one to power an EW Micro and/or future
transponder.
2NO
Old March 13th 09, 12:25 AM posted to rec.aviation.soaring
transponder.
2NO
I use 2 of the BB BP2.3-12 batteries wired together in parallel. They
measure 7.01" x 1.34" x 2.56" so if you tape them together top side to
top side they make a very nice package with 4.6 Ah of capacity. The
PS-1229 is basically the same I think though some resellers rate it at
2.9 Ah and some at 2.2 Ah. Best to look at the spec sheet as some
batteries are optimized for higher loads than others.
9B
Old March 13th 09, 12:35 AM posted to rec.aviation.soaring
Tuno
Andy,
Yes indeedy, those batteries have the same dimensions. Two of them
together will not only duplicate the fixed fin ballast I previously
used, but might also be able to power an xponder and EW Micro Recorder
for five hours.
2NO
Wing Baggage compartment - Tri-Motor Bo[_4_] Aviation Photos 1 November 27th 08 06:48 PM
WTB Schleicher ASK-21 ZZ Soaring 1 May 11th 08 11:21 PM
Uncontrolled Engine Compartment Fire Possible for Cessna 172R, 172S, 182T, T182T, 206H, and T206H Models Larry Dighera Piloting 0 April 19th 07 04:31 PM
Aztec extended baggage compartment STC Jim Burns[_2_] Owning 0 March 22nd 07 06:43 PM
160 new batteries Mal Soaring 0 October 27th 06 11:36 AM
