Google Earth viewer
Old May 8th 09, 09:07 PM posted to rec.aviation.soaring
Fred Blair
Default Google Earth viewer
I can't find it now, but there was an add in for Google Earth on here last
month that would replay an IGC file; it was so real to watch the tow from
our gliderport, just like a regular video.
Does anyone have the link?
Fred
Old May 8th 09, 09:13 PM posted to rec.aviation.soaring
Darryl Ramm
On May 8, 12:07*pm, "Fred Blair"
Fred
http://www.ywtw.de/igcsimen.html
Old May 8th 09, 09:18 PM posted to rec.aviation.soaring
Greg Arnold
Fred
http://ywtw.de/igcsimen.html
Old May 9th 09, 01:35 AM posted to rec.aviation.soaring
Fred
I did go to the link and downloaded the IGCconv for Window. However,
the subdirectory 'today' is empty, so I cannot call the script
'igcconv', that is supposed to be in there. Can any one walk me - a
computer techno-tard - through the process?
Uli Neumann
Old May 9th 09, 01:56 AM posted to rec.aviation.soaring
noel.wade
http://www.ywtw.de/igcsim.html
Enjoy!
--Noel
Old May 9th 09, 01:58 AM posted to rec.aviation.soaring
noel.wade
Uli -
You want to download and install the "Flight replay" tool, not the
converter.
You also need to have Google Earth installed first.
Good luck!
--Noel
Old May 9th 09, 02:20 AM posted to rec.aviation.soaring
On May 8, 7:58*pm, "noel.wade" wrote:
Uli -
converter.
Good luck!
--Noel
Noel,
thanks. Did that. Now I am getting a '.NET Framework Initialization
Error'. The text box reads: To run this application, you must first
install one of the following versions of the .NET Framework: v.
2.0.50727. Contact your application publisher for instructionsabout
obtaining the appropriate version of the .NET Framework.
Any suggestions?
Uli
Old May 9th 09, 02:36 AM posted to rec.aviation.soaring
Uli -
converter.
Good luck!
--Noel
Noel,
Any suggestions?
Uli
Never mind - found it. It is a Microsoft application that I downloaded
and installed.
It is working now!
Uli
You need to install Microsoft .Net Framework. You can download it at
http://www.microsoft.com/downloads/d...displaylang=en.
This should include the Framework and Service packs 1 and 2. It's a 37
Mb file.
Charlie
Uli -
converter.
Good luck!
--Noel
Noel,
Any suggestions?
Uli
Old May 9th 09, 02:42 AM posted to rec.aviation.soaring
Uli -
converter.
Good luck!
--Noel
Noel,
Any suggestions?
Uli
If you you are using Vista it is already installed. If not go to
and you will find the download for it there.
What on (Google) Earth... ?? GM Soaring 9 March 28th 08 05:54 AM
Saw This On Google Earth John[_1_] Naval Aviation 3 January 27th 08 01:25 AM
Google Earth Frank Whiteley Soaring 3 November 16th 07 01:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 05:31 PM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 01:07 PM
