ASW-20C Gear Warning Switch Placement
Old May 14th 09, 10:41 PM posted to rec.aviation.soaring
Jim Kellett
Default ASW-20C Gear Warning Switch Placement
Trying to figure out the best places to install the microswitches on
the spoiler and gear. Do not want ANY exposed wiring.
H3, Front Royal, VA.
Old May 15th 09, 02:05 AM posted to rec.aviation.soaring
Dan[_6_]
the spoiler and gear. *Do not want ANY exposed wiring.
on my ASW-20 the spoiler microswitch is mounted on the left hand
spoler bellcrank in the fuselage, easy access though the acess hole,
and the other one is on the spoiler guide rod under the seat pan on
the left forward side of the cockpit area.
hope that helps,
Dan Rihn
WO
Old May 15th 09, 02:06 AM posted to rec.aviation.soaring
Dan[_6_]
Sorry, I meant the gear handle guide rod not the spoiler guide rod.
Dan
WO
Old May 16th 09, 02:20 AM posted to rec.aviation.soaring
ContestID67[_2_]
The trick in all these implementations is finding 1) a place to mount
the switch and 2) a place that has something that moves at (generally)
right angles to trip the switch.
I don't suggest microswitches. They have to touch something, which I
try to avoid, especially for standard certified gliders. Another
thing is finding something that will touch and trip the switch. Often
this severely limits the placement of the switches or requires adding
a right angle "doo-thingy" as an arm to push the switch closed (or
open).
I prefer magnetic switches. These come as a pair, an actuator
(magnet) and a sensor (switch). Once the magnet gets next to the
sensor, the switch inside trips. Very reliable, quiet, and smooth.
These work very well to trip a switch when the thing that is moving
(like a spoiler actuator) is moving horizontally or is rotating so the
switch can be placed almost anywhere. See http://cumulus-soaring.com/hamlin.htm
for details.
My $0.02.
Good luck, John DeRosa
Stall warning switch for Cessna 206? [email protected] Owning 1 February 20th 07 10:16 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 11:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 04:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 09:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 09:33 AM
