Winch Launch Fatality
Old June 18th 09, 12:00 AM posted to rec.aviation.soaring
Nyal Williams[_2_]
Default Winch Launch Fatality
Who knows details about this?
http://www.mlive.com/news/annarborne...170.xml&coll=2
Old June 18th 09, 12:48 AM posted to rec.aviation.soaring
http://www.mlive.com/news/annarborne...news-32/124507...
No details but I flew there a few years ago with the club Pres in a
Lark. I think they have K13s as well.
Terrible news.
Old June 18th 09, 01:11 AM posted to rec.aviation.soaring
Barny
The survivor PIC is the former president you probably flew with in
the Lark. He's expected to recover from a broken back and leg.
Fatality was a guest demo ride, who was interested in taking lessons.
The other fatality in the article had nothing to do with the glider
ops or airport. It was a power plane crossing the area, after engine
trouble he tried unsuccessfully to reach the field. He passed over
several miles of landable fields and a test track to crash 1000's of
feet short.
Old June 19th 09, 05:26 AM posted to rec.aviation.soaring
On Jun 17, 6:11*pm, Barny wrote:
*The survivor PIC is the former president you probably flew with in
*Fatality was a guest demo ride, who was interested in taking lessons.
Oh man that is just rotton. I'm so sorry to hear it. A real tragedy
for all.
Matt Michael
Old June 19th 09, 06:03 AM posted to rec.aviation.soaring
Dave Doe
says...
There is some more info here...
http://www.stuff.co.nz/national/2515...wi-pilot-named
United States police today released the name of a New Zealand pilot
killed last Sunday when the glider in which he was a passenger crashed.
Timothy John Moxham, 29, was a pilot for an air ambulance, Midwest
Medflight.
Police said a delay in releasing details of his identity was because of
the difficulty in reaching his parents in New Zealand.
Mr Moxham died in a glider owned by the Sandhill Soaring Club and flown
by the club president when it crashed near Ann Arbor, Michigan.
Preliminary investigation indicated a winch cable used to help the
aircraft take flight may have failed on takeoff, police chief William
Cook of the nearby Unadilla Township told the Daily Press and Argus
newspaper. The Federal Aviation Administration is investigating.
The glider pilot, Orrin Burns Beckham, 63, of Ann Arbor, is in a serious
condition in a local hospital.
A colleague of the New Zealander, Medflight paramedic Andrew King said
Mr Moxham took his job to heart.
"Not only did Tim love flying and love being a pilot, but he loved being
a part of the (team) and getting people to the appropriate hospitals."
Mr King said Mr Moxham's desire to go gliding was recent. He said prior
to the trip, Moxham told him: "This is true flying. It's just you and
(nature)."
The New Zealander had been flying for more than 15 years, starting at
the age of 13 when his father taught him, and had logged more than 3000
hours of flight time, including flying offshore, corporate work and
flight instruction.
He also held certification to an FAA standards on airframe construction
and engine mechanics.
"People say we've lost a pilot, but he was so much more than that," said
another colleague, Medflight nurse Doug Berry. "He had such compassion
for the job and the people we transported. He cared about people.
"He touched the lives of hundreds of people," Mr Berry added, choking
back tears. "He was amazing."
- NZPA
Duncan
Old June 21st 09, 04:45 AM posted to rec.aviation.soaring
Ron Ogden
At 04:03 19 June 2009, Dave Doe wrote:
says...
Medflight.
(nature)."
flight instruction.
- NZPA
Duncan
NTSB prelim is at
http://www.ntsb.gov/ntsb/brief.asp?e...15X13631&key=1
Old June 22nd 09, 12:05 PM posted to rec.aviation.soaring
Dave Doe
says...
says...
Medflight.
(nature)."
flight instruction.
- NZPA
Duncan
NTSB prelim is at
Thanks Ron.
I see...
Witnesses reported that the glider was launched with a winch and during
the procedure the winch cable broke. The pilot executed a 180-degree
turn apparently in an attempt to return to the airport. However, near
the completion of the turn, the nose of the glider dropped and it
impacted the terrain.
How many times!!! - *don't* try to return to the field! OK, I don't
know the altitude (AGL) nor what was ahead of the field, but hey, we all
know, this is generally regarded as a no-no.
Duncan
Old June 22nd 09, 12:48 PM posted to rec.aviation.soaring
Scott[_7_]
Dave Doe wrote:
says...
says...
Medflight.
(nature)."
flight instruction.
- NZPA
Duncan
NTSB prelim is at
Thanks Ron.
I see...
And...it's never really a 180 degree turn...if you are departing on the
runway centerline and make a 180, your heading will be 180 degrees from
what is was on departure, but you won't be lined up with the runway you
just left, so you will have to make something like a 270 degree turn
followed by a 90 degree turn in the opposite direction to line up with
the runway, so basically, you've made a 360 turn (unless you were able
to execute a split-S).
Granted, we don't know what the altitude was, but per all of our
training, you generally want to "FLY THE AIRPLANE" and continue generall
straight ahead with maybe slight course corrections to avoid nasty
objects that would give you a rapid stop such as a building, cliff wall,
etc. At glider speeds, one should have a pretty good chance of walking
away from even a tree top landing.
Old June 22nd 09, 01:45 PM posted to rec.aviation.soaring
Del C[_2_]
Generally it is OK to make 180 or 360 degree turns in a modern gliders, as
long as you start at at least 300ft and keep the airspeed up to a safe
manoeuvring speed. The failure to do the latter seems to have been the
probably cause of this accident.
Also US glider pilots, mostly trained on aerotows, may not have properly
thought through the options available after a winch launch cable break.
Derek Copeland (UK gliding instructor)
At 10:48 22 June 2009, Scott wrote:
Dave Doe wrote:
says...
says...
crashed.
Medflight.
of
flown
serious
being
hospitals."
prior
and
(nature)."
3000
flight instruction.
construction
that,"
compassion
choking
- NZPA
Duncan
NTSB prelim is at
Thanks Ron.
I see...
all
generall
Old June 22nd 09, 01:59 PM posted to rec.aviation.soaring
Andreas Maurer
Completely wrong for a winch launch.
In case of a rope-break, you are either able to land straight-on on
the airfield, or you have sufficient altitude(300 ft+) to fly a
*safe* pattern.
Pay out winch launch to 2500ft agl.. WAVEGURU Soaring 8 June 5th 07 08:06 AM
Winch Launch Videos Mike Schumann Soaring 2 January 20th 06 12:27 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 01:33 AM
Electric winch fatality story in August Soaring Bill Daniels Soaring 0 August 14th 04 03:37 AM
Winch launch M B Soaring 0 October 30th 03 08:33 PM
