I've been flying gliders for years, but the following question only
occurred to me recently: In mechanically compensated varios, the TE pressure is supposed to be as much below static as pitot is above that. That makes sense since "ram air pressure" increases as v^2, as does the kinetic energy of the ship. But pitot pressure is proportional to IAS, whereas the kinetic energy of the ship would seem to need TAS. If I haven't made a mistake (and please correct me if I have), TE compensation will only be correct at one altitude. At higher altitudes it will be under compensated, and at lower altitudes over compensated. Comments please! Martin |
The TE pressure is not necessarily equal to the difference between static
and pitot. It is unlikely to be nor does have to. The working principle is that the static pressure changes with altitude, but as the TE pressure is reduced when you go faster and vice versa, the two components should cancel each other if you push or pull. If they do not you have climbed / sunk due to rising / falling air. Jim At 01:39 18 June 2009, Hellman wrote: I've been flying gliders for years, but the following question only occurred to me recently: In mechanically compensated varios, the TE pressure is supposed to be as much below static as pitot is above that. That makes sense since "ram air pressure" increases as v^2, as does the kinetic energy of the ship. But pitot pressure is proportional to IAS, whereas the kinetic energy of the ship would seem to need TAS. If I haven't made a mistake (and please correct me if I have), TE compensation will only be correct at one altitude. At higher altitudes it will be under compensated, and at lower altitudes over compensated. Comments please! Martin |
On Jun 18, 1:39*pm, Hellman wrote:
I've been flying gliders for years, but the following question only occurred to me recently: In mechanically compensated varios, the TE pressure is supposed to be as much below static as pitot is above that. That makes sense since "ram air pressure" increases as v^2, as does the kinetic energy of the ship. But pitot pressure is proportional to IAS, whereas the kinetic energy of the ship would seem to need TAS. If I haven't made a mistake (and please correct me if I have), TE compensation will only be correct at one altitude. At higher altitudes it will be under compensated, and at lower altitudes over compensated. Comments please! Of course you are correct that at a given TAS the suction generated in the TE probe will decrease proportional to the air density at that altitude. However don't forget that the rate of air density at altitude does not decrease linearly. The air pressure at altitudes we fly at is pretty much 1013 / 2^ (altitude/18000). If you work out the derivative of that you'll find the rate of change of pressure at a particular altitude is proportional to the pressure at that height. That means that the change in potential energy from a 1m change in height will *also* be misread proportional to the air density at that height. So the two effects cancel each other out. |
On Jun 17, 7:39*pm, Hellman wrote:
I've been flying gliders for years, but the following question only occurred to me recently: In mechanically compensated varios, the TE pressure is supposed to be as much below static as pitot is above that. That makes sense since "ram air pressure" increases as v^2, as does the kinetic energy of the ship. But pitot pressure is proportional to IAS, whereas the kinetic energy of the ship would seem to need TAS. If I haven't made a mistake (and please correct me if I have), TE compensation will only be correct at one altitude. At higher altitudes it will be under compensated, and at lower altitudes over compensated. Comments please! Martin I predict this will be a long thread. First principles: Total energy vario systems sum the kinetic energy of speed and the potential energy of height and display the rate at which that sum is changing with time in knots or meters per second. This calculation must be done in the same domain and in the same units. i.e. true airspeed + true rate of climb or indicated airspeed + indicated rate of climb in the air-data domain. TE calculations can also be done entirely in the inertial domain though no such system exists to my knowledge. Don't mix units or domains. An example is the Borgelt B50/B500 varios which are altitude compensated to give true rate of climb and which calculate TE with true airspeed to produce a fast, smooth and accurate TE vario. These varios, like most, use a probe which may be regarded as a special static port which is carefully crafted to respond in a precise way to airspeed changes while being relatively insensitive to yaw and pitch angles. The real 'magic' of an air-data TE vario is in the probe. You could, if so inclined, connect the TE port on the vario to regular static ports and have a perfectly workable, if non-compensated, vario. |
If you accept
0.5*rho*v^2 + rho*g*h + p = const then the density cancels out when you trade-off a delta_h for a delta_v^2. Larry |
On Jun 18, 12:31*pm, bildan wrote:
This calculation must be done in the same domain and in the same units. *i.e. true airspeed + true rate of climb or indicated airspeed + indicated rate of climb in the air-data domain. *TE calculations can also be done entirely in the inertial domain though no such system exists to my knowledge. Don't mix units or domains. I think you've have hit the nail on the head. It's annoying that I missed that since I'd wondered some time ago about indicated vs. true rate of climb. The only remaining question in my mind is if IAS and IROC (Indicated ROC) change in the right manner. At 18k feet where the atmospheric density is roughly half that at sea level, TAS = SQRT(2) * IAS and "true kinetic energy" will be twice "indicated KE." For the two factors to cancel out, it would seem that the TROC (true ROC) would have to be twice the IROC, and that sounds right. But it would be nice if you could say a few words about why that's the case. Here's what I can see right now: If, as I seem to remember (and makes intuitive sense), pressure vs. altitude decays exponential, then the derivative of pressure versus altitude will be half what it was at sea level. If the vario measures the rate of change of pressure, then we'd get the factor of 2 we need and all would be well, but ... the capacity bottle has only half as many air molecules. If that has any impact on the vario (over and above the factor of 2 mentioned above), then it would seem like compensation would be altitude dependent. I suspect that it does not, but any words on why would be appreciated. Thanks. Martin |
On Jun 20, 12:18*am, Hellman wrote:
On Jun 18, 12:31*pm, bildan wrote: This calculation must be done in the same domain and in the same units. *i.e. true airspeed + true rate of climb or indicated airspeed + indicated rate of climb in the air-data domain. *TE calculations can also be done entirely in the inertial domain though no such system exists to my knowledge. Don't mix units or domains. I think you've have hit the nail on the head. It's annoying that I missed that since I'd wondered some time ago about indicated vs. true rate of climb. The only remaining question in my mind is if IAS and IROC (Indicated ROC) change in the right manner. At 18k feet where the atmospheric density is roughly half that at sea level, TAS = SQRT(2) * IAS and "true kinetic energy" will be twice "indicated KE." For the two factors to cancel out, it would seem that the TROC (true ROC) would have to be twice the IROC, and that sounds right. But it would be nice if you could say a few words about why that's the case. Here's what I can see right now: If, as I seem to remember (and makes intuitive sense), pressure vs. altitude decays exponential, then the derivative of pressure versus altitude will be half what it was at sea level. If the vario measures the rate of change of pressure, then we'd get the factor of 2 we need and all would be well, but ... the capacity bottle has only half as many air molecules. If that has any impact on the vario (over and above the factor of 2 mentioned above), then it would seem like compensation would be altitude dependent. I suspect that it does not, but any words on why would be appreciated. Thanks. Martin I'd say it is worthwhile to have an altitude compensated vario. If you start with that, then you have to use true airspeed to do the TE calculation. More interesting to me is the relatively new Inertial Reference Units (IRU's) that have been developed for UAV's. These are small, light, use little power, are accurate and are available at a reasonable cost. In addition to position data, Euler angles, and 3D acceleration, they provide very accurate 3D velocity data. The horizontal and vertical velocity can be used for a nearly perfect TE vario. It would be immune to gusts and would have instantaneous response. The vario reading should be very smooth since it's measuring the actual velocity of the glider without any probes or air data at all. In addition to perfect vario data, together with true airspeed, could provide highly accurate real time vector winds. |
| Thread Tools | |
| Display Modes | |
| Young Eagles/Compensation | Kyle Boatright | Piloting | 6 | April 15th 06 01:03 AM |
| Pilot Compensation - FAR 61.113 | CAE | Piloting | 12 | February 7th 06 11:21 PM |
| Compensation vs. Cost sharing? | Mark Morissette | Piloting | 9 | April 19th 05 06:42 AM |
| Cambridge 302 compensation opinions | Caracole | Soaring | 8 | June 27th 04 09:19 PM |
| interview travel compensation | David Martin | Piloting | 1 | June 4th 04 04:40 AM |
