Parowan Fatal Crash
Old July 1st 09, 06:55 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default Parowan Fatal Crash
http://www.sltrib.com/news/ci_12717073
Old July 1st 09, 07:21 PM posted to rec.aviation.soaring
Frank Whiteley
There've been some conflicting reports. This has a bit more detail
http://www.thespectrum.com/article/2...ims+man+s+life
Old July 1st 09, 07:41 PM posted to rec.aviation.soaring
Ramy
There've been some conflicting reports. *This has a bit more detailhttp://www.thespectrum.com/article/20090701/NEWS01/907010314/Glider+a...
We are having a horrible year. 2 fatal crashes in 2 US regional
contests one day after the other. Both sounds like the glider suddenly
plummeted to the ground. Very depressing. I hope we will find out one
day why very experienced pilots suddenly loose control and hit the
ground.
Ramy
Old July 1st 09, 08:01 PM posted to rec.aviation.soaring
ground.
Ramy
This is a sad reminder that any of us can kill themselves. There is no
absolute solution, short of not flying, but there are things we can
all do.
1) Study these events and learn from them
2) Get some additional training
3) Fly regularly. Get advice from good sources- who may not tell you
what you want to hear.
4) Promise ourselves(and our families) that we will look for risks and
eliminate them, or at least minimize them. THEN- Do what we promise
ourselves.
5) Never count on luck.
From a guy that got away with one(and didn't think he would ever put
himself in that kind of situation).
FWIW
UH
Old July 1st 09, 08:49 PM posted to rec.aviation.soaring
Ramy
ground.
Ramy
all do.
ourselves.
FWIW
UH
I agree. But I am especially bothered by accidents that don't seem to
fall under any of the above critical points.
Ramy
Old July 1st 09, 09:27 PM posted to rec.aviation.soaring
ground.
Ramy
all do.
ourselves.
FWIW
UH
Ramy- Hide quoted text -
- Show quoted text -
Speculation on my part- It would be interesting to know when the past
time either of these folks spun a glider and if either had ever spun
the glider they were flying.
When I ask this question of most pilots, the answer I get is that they
never have.
Again FWIW
UH
Old July 1st 09, 09:31 PM posted to rec.aviation.soaring
noel.wade
Ramy
Ramy -
While its too early to talk about accident causation, in both cases
there appears to be some stall/spin behavior in the chain of events.
Stall/spin accidents are a known problem and an area that _all_ pilots
should be aware of. There is no excuse for not practicing them and/or
taking spin recovery training.
Every pilot should understand their CG (and its effects on stall/spin
behavior of their particular aircraft). They should also think about
stall/spin behavior and CG changes when they load up on water ballast
as well.
--Noel
Old July 1st 09, 09:35 PM posted to rec.aviation.soaring
mike
On Jul 1, 12:27�pm, wrote:
On Jul 1, 2:49�pm, Ramy wrote:
On Jul 1, 11:01�am, wrote:
On Jul 1, 1:41�pm, Ramy wrote:
On Jul 1, 10:21�am, Frank Whiteley wrote:
There've been some conflicting reports. �This has a bit more detailhttp://www.thespectrum.com/article/20090701/NEWS01/907010314/Glider+a...
ground.
Ramy
all do.
ourselves.
FWIW
UH
never have.
Again FWIW
UH- Hide quoted text -
I'd have to add that it's important to be in good health. You don't
want to have any issues, especially in conditions that may cause
stress like contests and weather (as in heat).
Mike Z
Old July 1st 09, 10:01 PM posted to rec.aviation.soaring
Craig[_2_]
Ramy
Ramy -
should be aware of. *There is no excuse for not practicing them and/or
behavior of their particular aircraft). *They should also think about
as well.
--Noel
Some of our birds are placarded against spinning (my Nimbus 3
included). Spin training is a must, but something like a Blanik won't
necessarily prepare a pilot for a glider with a less benign spin
mode. All of our machines "talk" to us in the air. The best thing we
can do is learn how to really listen to them.
Craig
Old July 1st 09, 11:32 PM posted to rec.aviation.soaring
bildan
Ramy
Ramy -
as well.
--Noel
included). *Spin training is a must, but something like a Blanik won't
mode. *All of our machines "talk" to us in the air. *The best thing we
Craig
After many years of first learning spins, practicing them and finally
teaching them, I've developed the opinion that what we do to teach
spins has little to do with the actual killer spin. Who would
inadvertently haul the nose way up then stomp full rudder at the stall
break?
The people who taught me the killer spin were my students. As in, "I
didn't know a glider would do that." It helps to have a easily
spinable glider like a 2-32, Blanik or Lark although the 2-32 tends to
spin too easily.
These spins require a set up. First, fly at minimum controllable
airspeed for at least 30 seconds. Try to let the glider slowly and
smoothly enter "mushing flight". In "mushing flight" the glider is
not quite stalled but the airflow over the wing has become unstable.
Any disturbance will trip it into a full stall. The angle of attack
is very high due to the sink rate - not a nose high attitude. In
fact, the nose can be near the usual gliding attitude.
Any attempt to turn will trip an asymmetric stall which will develop
into a spin in less than a second. Just before the glider spins,
everything "looks" normal. (Except, of course, for the ridiculously
low airspeed, sloppy controls, absence of wind noise etc...) Several
high time glider pilots doing a BFR with me didn't see this one coming
and were visibly shaken by their 'inadvertent spin'.
What happens next is crucial. If the pilot does nothing, the glider
is likely to transition into a spiral dive. If the pilot then applies
spin recovery control inputs the spiral dive will become much worse.
Some of the scariest rides I've had is with a pilot using "anti-spin"
control inputs while in a spiral dive.
In most fatal "spin-in" accidents, I think the glider is likely to
have transitioned to a spiral dive before impact. This can also
explain some in-flight breakups following an inadvertent spin.
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 03:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 10:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 06:03 AM
Fatal crash at Fuentemillanos ns51645 Soaring 0 January 24th 04 10:45 AM
Fatal Crash at Robinson Steve Rotorcraft 5 November 10th 03 05:27 PM
