F8 Crusader Variable Incidence Wing
Old July 14th 09, 03:20 AM posted to rec.aviation.military.naval,rec.aviation.military
Default F8 Crusader Variable Incidence Wing
The Vought F8 Crusader was the only production military aircraft I
know of with a variable incidence wing. This feature was used to
improve pilot visibility on take off and landing, a critically
important thing for a carrier plane; several aircraft such as the
earlier Vought Cutlass and Douglas Skyray had the nose and cockpit
greatly revised in production versions for better visibility.
In operation off land bases, did the variable incidence wing have any
disadvantages? Did the approximately 7 degree wing incidence cause any
noticeable increase in drag during the take off run? In landing, did
the wing produce undesirable continued lift after touch down that
reduced braking action? Was it possible or practical to level the wing
after touch down to kill the lift, similar in effect to extending
spoilers on some aircraft?
Thank you,
Peter Wezeman
anti-social Darwinist
Skybolt Tail Incidence Question Scott Rodriguez Home Built 1 November 20th 05 08:44 PM
Skybolt Tail Incidence Question Scott Rodriguez Aerobatics 0 November 4th 05 05:16 PM
Better GPS, Flight Computer, Variable Wing Geometry, abililty to Self-Launch Stewart Kissel Soaring 7 May 2nd 05 07:02 PM
Variable geometry intakes Boomer Military Aviation 17 April 12th 04 10:42 PM
want variable pitch prop Ray Toews Home Built 5 October 7th 03 10:59 PM
