SAFE Winch Launching and automatic gearboxes
Old July 20th 09, 06:25 PM posted to rec.aviation.soaring
bildan
Default SAFE Winch Launching and automatic gearboxes
On Jul 20, 8:15*am, Don Johnstone wrote:
... *a "tension controlled" winch is about the craziest idea I have
ever
heard, not least because, thankfully, it would never work.
Why not?
Brian W
Because there is no direct relationship between the tension experienced at
the winch and that experienced at the glider release using wire rope.
Even with plastic rope the relationship is tenuous at best, the rope does
have some mass and in addition has an elastic quality as well. The
tensions experienced at each end of the cable can be vastly different and
are different more often than they are equal, so measuring at the winch
end tells you very little about what is happening at the glider, it may
indicate what has happened but even this is not likely to be very
accurate.
Lets see, you pull on a rope but the force is "vastly different" at
each end? I can hear millions of teenage science students laughing at
that.
The weight of steel cable does have an effect but not it's
elasticity. Plasma rope has neither a lot of weight nor elasticity.
The tension at the winch and glider are the same to several
significant digits.
SAFE Winch Launching Derek Copeland[_2_] Soaring 185 August 2nd 17 08:12 PM
SAFE Winch Launching and automatic gearboxes bildan Soaring 2 July 20th 09 08:17 PM
Winch Launching in US john hawkins Soaring 11 June 10th 09 01:18 PM
Winch Launching Rolf Soaring 27 January 7th 09 03:48 AM
Ka8b winch launching Jimmie L. Coulthard Soaring 11 September 9th 08 09:38 AM
