working with kevlar
Old July 23rd 09, 02:24 AM posted to rec.aviation.soaring
Brad[_2_]
Default working with kevlar
anyone have some tips on working with kevlar? specifically, how to
avoid or at least to control the fuzzing when sanded or trimmed?
am interested in getting the trailing edge of a kevlar control surface
nice and straight.........
thanks,
Brad
Old July 23rd 09, 03:43 AM posted to rec.aviation.soaring
Mike Bamberg
thanks,
Brad
It's very easy, never take the kevlar to the edge! Replace the kevlar
of the layup with with equal thickness glass or carbon within 1/2 of
the edge. Be sure there is a "tune-able" (read that sacrificial)
layer over the kevlar if you expect to sand the surface.
If you really need to take the kevlar to the edge of a surface, the
best way to trim it is with a shear, no rotary cutters or sanding.
Log onto several of the model soaring forums and look at the
structures they are creating with Kevlar and carbon.
Old July 23rd 09, 12:01 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On Wed, 22 Jul 2009 18:43:57 -0700, Mike Bamberg wrote:
If you really need to take the kevlar to the edge of a surface, the best
Agreed: my (limited) modeling experience with Kevlar says never sand it.
Weight for weight Kevlar usually is a coarser fabric than glass and so is
likely to leave a textured surface if its the outer layer but you can
loose a lot of that merely by using light glasscloth (25 gsm, 0.8 oz/yd)
as the outer layer. As a bonus, that also gives you something to sand if
you really must.
The light stuff (70 gsm or less) is hard to cut cleanly because the
shears or sharp knife tend to distort the weave. Putting masking tape on
one side of the fabric and cutting down the middle of the tape helps a
lot.
Log onto several of the model soaring forums and look at the structures
Good advice.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 23rd 09, 02:44 PM posted to rec.aviation.soaring
thanks,
Brad
I have had some luck sealing the fuzz with cyanoacrylate(Zap is model
brand- use thick stuff) to satnd up the fuzz and permit sanding.
This should get you by for what you are working on now. Best bet is
avoid by ending Kevlar layer just a little short of edge.
Good luck
UH
Old July 23rd 09, 05:20 PM posted to rec.aviation.soaring
Uncle Fuzzy
thanks,
Brad
Good luck
UH
I'm one of the model builders that has also messed with Kevlar. At
this stage, you're already "fuzzed". A possible 'fix' is to continue
sanding until you're a few thousands under your desired profile, then
bag on some light glass cloth. There's no GOOD way to deal with the
Kevlar fuzz.
Old July 23rd 09, 05:27 PM posted to rec.aviation.soaring
gliderman
thanks,
Brad
After sanding, you can use a "super glue" (cyanoacrylate) with the
spray on accelerator. Use lot's of accelerator so that the glue
appears to foam up (This makes it brittle and no good as a glue). Then
use a razor knife or an exacto to scrape/cut the fuzz away.
Old July 23rd 09, 05:40 PM posted to rec.aviation.soaring
Brad[_2_]
Thanks for the tips everyone!
We did use a mold side E-glass veil to give us a working/sandable
surface, but too bad I did not think about holding short at the TE and
using 7725, that would have made the TE trim a piece of cake instead
of a gin-fuzz......
Will let you all know how things turn out. The Kevlar flaperons are
nice and floppy, much more so than the carbon one I made, the carbon
flaperon was very nice to build and easily trimmed but we deemed it
too stiff.
Brad
Old July 24th 09, 10:02 PM posted to rec.aviation.soaring
JohnElliott
The thread below suggests water sanding Kevlar with 120 grit:
http://www.express-builder.com/forum...tml?1190005809
Exerpt from above thread:
I have talked to several builders trying to use kevlar composites.
Common problem to all of them are the way kevlar behaves when sanding
it.
All edges sanded the normal way gets the look of a "used toothbrush".
This problem limits kevlar use to places where it will be totally
contained inside other structural parts. Now I found out that it is
possible to sand kevlar edges with good result. I used normal water
sanding technique with no:120 grit and this will give you a smooth
edge just as when sanding a fiberglass counterpart.
Old July 25th 09, 02:45 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
it.
You might want to check this out with the resin manufacturer. While water
sanding is used on gel coat, which is polyester resin I have not seen it
used on epoxy resin structures. One of the purposes of gel coat/paint is
to prevent water getting to the underlying epoxy structure which is
hydroscopic.
Working on the G-III Roger[_4_] Piloting 0 March 22nd 08 07:13 AM
Kevlar - Styrofoam material, where to get more [email protected] Home Built 8 February 20th 08 02:08 AM
kevlar in fuselage Rick Walters Soaring 2 January 20th 05 11:59 PM
Adding Kevlar to cockpit floor or seatpan? Stewart Kissel Soaring 10 January 19th 05 09:36 PM
How is IFF working? Tobias Endrullis Military Aviation 8 November 30th 03 04:06 PM
