Fky with Ce/OLC
Old August 7th 09, 04:41 AM posted to rec.aviation.soaring
jeplane
Default Fky with Ce/OLC
All my flights end up with Validation not successfull, Flight invalid.
I use a flywithCE recorder.
What is the reason? Thanks
090807 031438 - Flight claimed through Server_loggedOn
(timeofvaluation 191628 - 233116)
090807 031438 - Flight loaded for Batch Calculation
090807 031438 - File Quality is 100%
090807 031502 - Optimized flight for olc
090807 031540 - Optimized flight for olc-fai
090807 031559 - Optimized flight for olc-league
090807 031603 - Validation not successfull, Flight invalid
Old August 7th 09, 01:08 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I believe that the reason is that the OLC has not had time to "approve" that
logger yet. I'm not certain about that, but it would explain what you are
seeing. They need to do some software work to get new loggers into their
system. I recommend that you send them an e-mail using the support link on
their web site.
The same is true for the NK ClearNav. NK worked hard and received IGC
approval, but the OLC hasn't brought it into their system yet - which is
very frustrating for NK and NK ClearNav users.
Best Regards,
Paul Remde
"jeplane" wrote in message
Old August 7th 09, 02:07 PM posted to rec.aviation.soaring
Gaetan Trudel
On Aug 7, 8:08*am, "Paul Remde" wrote:
Hi,
logger yet. *I'm not certain about that, but it would explain what you are
seeing. *They need to do some software work to get new loggers into their
system. *I recommend that you send them an e-mail using the support link on
their web site.
The same is true for the NK ClearNav. *NK worked hard and received IGC
Best Regards,
Paul Remde
090807 031603 - Validation not successfull, Flight invalid- Hide quoted text -
- Show quoted text -
Hi
I have the same problem but not with all flight some are sign, ok for
OLC some are unsign, red button. But cant figure out why! I gave up.
Sent a email to flywithce but it came back!
Otherwise very convenient.
S6
Old August 7th 09, 10:50 PM posted to rec.aviation.soaring
Tim Mara[_2_]
OLC has also not been very quick to change settings to allow all systems
they have given approvals for and make settings on their end
any emails to FlywithCE should have FlywithCE, or Navigator in the subject
bar as they say on their website to avoid spam filtering
otherwise I know Uros is very quick to answer and always helpful
tim
"Gaetan Trudel" wrote in message
On Aug 7, 8:08 am, "Paul Remde" wrote:
Hi,
that
their web site.
Best Regards,
Paul Remde
text -
Hi
S6
