Home machining
Old August 15th 09, 03:28 AM posted to rec.aviation.homebuilt
Anthony W
Default Home machining
Can anyone recommend a good forum for home machine work? Not the news
group, that's a madhouse...
Tony
Old August 15th 09, 05:50 AM posted to rec.aviation.homebuilt
Dan[_12_]
Tony
If you want a place with good customer support try:
http://littlemachineshop.com/
The people there always answer my questions about how to do things
and the make suggestions for trouble I get myself into.
Dan, U.S. Air Force, retired
Old August 15th 09, 07:41 PM posted to rec.aviation.homebuilt
R[_2_]
Tony
The Home Machinist
http://www.chaski.org/homemachinist/
The Home Shop Machinist & Machinist's Workshop BBS
http://bbs.homeshopmachinist.net/
If you have some metalworking or machining experience this group has the
most expertise. They do not tolerate well inane questions from wannabes.
A wealth of knowledge can be gained by, even, lurking here.
Practical Machinist
http://www.practicalmachinist.com/vb/
Old August 15th 09, 11:48 PM posted to rec.aviation.homebuilt
Anthony W
Thanx guys I have book marked those pages.
Tony
Old August 16th 09, 12:41 AM posted to rec.aviation.homebuilt
Stu Fields
"R" wrote in message
Tony
The Home Machinist
most expertise. They do not tolerate well inane questions from wannabes. A
Practical Machinist
Thank you a bunch. The Practical Machinist is just what I've been looking
for...
Stu Fields Safari helicopter and now a Helicycle
Old August 16th 09, 02:10 AM posted to rec.aviation.homebuilt
Peter Dohm
Tony
The Home Machinist
Practical Machinist
Looking at this thread makes me just a little curious whether the
relationship of cost and capability may have brought the CNC routing/milling
process to make precision foam cores--such as used in the Vari-Eze and its
derivatives--within reasonable reach of the home builder. The hot wire
method worked reasonably well in its day; but was limited to certain types
of foam and also resulted in a slight sag in the shape of the resulting
parts.
Of course, I have kept a list of the above forum locations; and I am curious
if anyone happens to know the present cost of setting up that sort of CNC
system for the cores in something like a Vari-Eze.
Peter
Old August 16th 09, 04:05 AM posted to rec.aviation.homebuilt
Dan[_12_]
Tony
The Home Machinist
Practical Machinist
parts.
Peter
I would imagine it's a matter of scale. In theory it would be
possible, I have seen kits for 2 dimensional systems for using
oxy-acetylene torches to cut sheet metal and a home PC. I wonder if such
a sytem could be modified to 3 dimensions. Rigidity of the machinery
would require a rather massive frame. One additional consideration would
be dust collection.
I wonder if the system could also be used to finish the part after
layup.
A creative mind would be able make some amazing shapes.
Old August 16th 09, 04:31 AM posted to rec.aviation.homebuilt
Atheist Chaplain[_2_]
"Dan" wrote in message
Tony
The Home Machinist
Practical Machinist
routing/milling process to make precision foam cores--such as used in the
Vari-Eze and its derivatives--within reasonable reach of the home
builder. The hot wire method worked reasonably well in its day; but was
limited to certain types of foam and also resulted in a slight sag in the
shape of the resulting parts.
curious if anyone happens to know the present cost of setting up that
sort of CNC system for the cores in something like a Vari-Eze.
Peter
I would imagine it's a matter of scale. In theory it would be possible,
I have seen kits for 2 dimensional systems for using oxy-acetylene torches
to cut sheet metal and a home PC. I wonder if such a sytem could be
modified to 3 dimensions. Rigidity of the machinery would require a rather
massive frame. One additional consideration would be dust collection.
layup.
Here is a starting point :-)
http://www.instructables.com/id/How-...-Cheaply-and-/
[This comment is no longer available due to a copyright claim by Church of
Scientology International]
"I like your Christ. I do not like your Christians. They are so unlike your
Christ." Gandhi
Old August 16th 09, 11:58 AM posted to rec.aviation.homebuilt
R[_2_]
Peter
Along with Practical Machinist's, and Chaski's Home Machinist, CNC
sections, add for homebrew CNC:
CNCzone.com
http://www.cnczone.com/
A group to monitor, if you are interested in developing a homebrew CNC
machine to mill or cut out your next skychaser.
The cost depends on your own vision of the machine, the task, and your
expected production.
Old August 16th 09, 12:18 PM posted to rec.aviation.homebuilt
R[_2_]
CNCzone.com
OOPs!
link direct to the forums page:
http://www.cnczone.com/forums/index.php
Homebrew CNC machine's costs are determined by how good you can scrounge.
The Home-made Home-builders Engine Veeduber[_2_] Home Built 37 June 12th 09 04:22 AM
F-111 comes home Don Pyeatt Aviation Photos 1 May 5th 08 11:26 PM
Foamy's Home Away From Home Michael Baldwin, Bruce Products 0 December 22nd 06 11:14 AM
Exclusive Custom Home Plans, and Essential information about building your New Home orange tree Home Built 4 November 20th 05 04:37 PM
Welcome Home Meade Spotts Naval Aviation 0 March 11th 04 01:17 AM
