Ideal Variometer
Old August 20th 09, 05:21 PM posted to rec.aviation.soaring
ryanglover1969
Default Ideal Variometer
I have a few suggestions for the way my vario, an LX1600 should work,
ideally.
I would like it to switch between "STF mode" and "Climbing mode" when
I hit lift or sink. Ideally it should switch to climbing mode when I
hit lift that equals or exceeds my MC setting. Of course there would
still be a manual override switch when you are low and/or scratching.
Do other vario manufactures set up their varios to work the way I
describe? If so, which ones?
Currently it switches between modes using three methods all of which I
think are inferior. It will switch to Climbing mode when I start
turning, when the speed drops below a set value, or when I manually
switch modes.
How do other manufactures do it?
Thanks, Ryan
Working on the ideal single engine tug! TugMan Piloting 13 June 9th 06 01:37 AM
What is the ideal ILS antenna? billkennedy3 Home Built 8 October 5th 05 08:22 PM
Ideal Display Size Survey john smith Piloting 8 August 26th 05 06:43 PM
Ideal watch? Brinks Owning 45 December 24th 03 04:00 PM
ideal training glider M B Soaring 2 September 19th 03 11:15 PM
