Alright here's a question about top of useable lift for the blipmaps.
If the thermal tops are 7,000 and the cloudbases are 5,000 and the top of useable lift is 4,000 Does this mean that when you get to 4,000 you will have risen to the top and can only circle around in zero sink there? |
At 18:22 24 August 2009, Spam wrote:
Alright here's a question about top of useable lift for the blipmaps. If the thermal tops are 7,000 and the cloudbases are 5,000 and the top of useable lift is 4,000 Does this mean that when you get to 4,000 you will have risen to the top and can only circle around in zero sink there? by top of useable lift do you mean the hcrit parameter? if so then that is supposedly approximately the alititude where you will no longer be able to climb. be careful though, the NAM and RUC forecasts (at least around here) are often a bit optimistic on the temperature and dew points, which skews the forecast vs. reality. remember that the forecast temperature, dew point, sun heating, and everything else has to line up in order for the lift forecast to be valid as well. -Tony Condon Cherokee II N373Y |
On Aug 24, 2:45*pm, Tony Condon wrote:
At 18:22 24 August 2009, Spam wrote: Alright here's a question about top of useable lift for the blipmaps. If the thermal tops are 7,000 and the cloudbases are 5,000 and the top of useable lift is 4,000 Does this mean that when you get to 4,000 you will have risen to the top and can only circle around in zero sink there? Cherokee II N373Y My experience is that the "top of useable lift" is conservative; I find the NAM "Height of the Boundary Layer" to more accurately predict how high the "best" thermals will go. This from extensive soaring in Arizona and Illinois. YMMV, of course ;^) Kirk 66 |
remember that "thermal tops" is where the thermal either hits an inversion
layer or "the lifted air mass" has cooled to the actual temperature. The difference between "expected lapse rate temperature" and "actual measured temperature" becomes zero for gliders to effectively be able to climb, they need a "thermal index" or difference in temperatures between actual and expected lapse rate of about -3. Considering the std lapse rate of about 2.5C per 1000ft, that works out. There may still be some lift at 4000ft, most gliders have a "sink rate" of about 1.2 to 1.7knts (120fpm) and if the lifting air mass has slowed or reached about the same... then yes.. you may have reached "zero sink". The other posted responses cover what they use in the forecast to best determine the "lift band" BT "Spam" wrote in message ... Alright here's a question about top of useable lift for the blipmaps. If the thermal tops are 7,000 and the cloudbases are 5,000 and the top of useable lift is 4,000 Does this mean that when you get to 4,000 you will have risen to the top and can only circle around in zero sink there? |
| Thread Tools | |
| Display Modes | |
| BLIPMAPS and GPS_LOG | Henryk Birecki | Soaring | 0 | June 7th 07 11:19 PM |
| Blipmaps | Tom Ruble | Soaring | 4 | May 27th 04 03:48 AM |
| ETA BLIPMAPs | DrJack | Soaring | 0 | March 1st 04 04:18 AM |
| Dr Jack's BLIPMAPS | Jim | Soaring | 7 | December 2nd 03 09:44 PM |
| Contribute to BLIPMAPS (was Biting the (weather) hand that feeds) | Mark James Boyd | Soaring | 0 | August 12th 03 10:40 PM |
