X-Plane for aircraft design
Old August 28th 05, 12:43 AM
Ghazan Haider
Default X-Plane for aircraft design
Can X-plane be used to design aircraft?
I've been trying to design aircraft in it, but most of my designs just
crash immediately as it starts in a fraction of a second, even though
most of the details are pretty reasonable (if the engine horsepower is
0, it just sits there, if its 1, it crashes immediately even though the
aircraft weight is 100-1000lbs).
I've been trying to check designs that I could use for RC airplanes.
The airplanes I've tried to design are of reasonable size; 20ft
wingspan, dihederal wings, 500lbs total weight with the CoG at the 25%
from leading edge of the main wing under the fuselage. Also the CoG is
well within the landing gear triangle (including fuel weight). How
realistic is designing aircraft in X-Plane? Can I trust it enough for
simple slow flight in a reasonable-size prop airplane?
Old August 28th 05, 10:17 AM
Tommi Raulahti
Originally Austin made X-Plane for commercial use for small companies
to make prototypes and fly them on computer before making real
prototype to testflight... So I'll assume it most likely is pretty
accurate if you make plane with care.
(I had a vision to test one day, how well toilet seat flies).
- Tommi -
My first lesson Marco Rispoli Aerobatics 3 May 17th 05 09:23 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 08:27 AM
more reasons for GA: John Gilmo I was ejected from a plane for wearing "Suspected Terrorist" button Martin Hotze Piloting 80 August 3rd 03 01:41 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 08:27 AM
