I've read your symptoms per your orig post, and you have one odd
collection of seemingly mutually-exclusive symptoms. If you can xmit, but not receive, it's not the coax. The weird symptom that goes along with the not receiving is the loss of sidetone, when I attempt to xmit. That's the part that confuses me, and leads me to question whether I can receive or not... Maybe I am receiving, but just can't hear it??? I don't completely understand how the radio, intercom and audio panel all tie together, so I'm confused at the various symptoms I am encountering. i.e. a) clear side-tone when talking over the intercom (no depression of the PTT) and able to talk and listen to passengers. b) obviously clear transmission (pressing PTT) but no sidetone and passenger doesn't hear me either. (I say obviously clear because ATC acknowledged my transmission, which I was able to confirm over a hand-held) c) Not hearing radio calls (confirmed by listening and hearing them on a hand-held). Sidetone is a function of the intercom, is it not? Meaning, if I were to bypass the intercom and plug directly into the aircraft jacks (which I have tried) I would not hear sidetone, when I attempted to transmit. Either way, I was unable to hear known ATC coms while plugged directly into the aircraft jacks. Scratchiness, followed by silence, isn't likely the connector, nor coax. Is that what it still does? It seems the first time it fails, it tends to fade out with scratchiness. The last time I flew, I was able to turn the radio off for a few seconds and turn it back on, to find it working for a minute or two. This worked a few times, but failed to work, at all, the last two times I tried it. The real ****er is that once I get it on the ground, it seems to work fine! It sounds like a thermal fault in the squelch circuitry. Narco uses a large fancy squelch circuit, squelching in 2 different ways and works on a hair trigger. Bad thermal behavior of a component could cause grief. My Narco comm 120 does similar and obviously a thermal, w/o the annunciating scratchiness. Similar circuit; no time to pull and fix in such nice weather yet. I just had the radio in for some questionable repairs at an avionics shop that is a certified Narco dealer. They ran it up on the bench for 4 or 5 hours, and said that everything was within specifications... Is this something a normal bench runup would be able to detect? You can't pull the tray without dealing with the wires at the connector. If you can do that, you can just visually inspect the stuff for integrity. At some point, before my last two flights, I crawled into that wonderful position with my head between the rudder pedals and reached my arm up behind the radio to see if I could feel anything out of the ordinary (like I would know what ordinary felt like!). I grabbed at the cables and wires and performed a wiggle-and-seat manuver for everything I could blindly grab... My following two flights, each nearly two hours, resulted in no radio failures. I was convinced the problem was gone (okay, I was praying that the problem was gone). However, the last two times I flew, it was back... This is when I decided that I might have temporarily fixed something, but that vibration had caught back up with me and undid what I fixed. My hope was that removing and cleaning all connection points and making sure everything is seated snugly when reinstalled, would fix my problem once and for all. The worst case scenario is $20 of coax cable and pulling back bloody stumps when I try to retrieve my arms from behind the panel. If I take it to an avionics shop at this point, I will be looking at a minimum of $300 to troubleshoot, and I have already dumped nearly $600 for a questionable radio repair and a new antenna, while shotgun troubleshooting. For thermal, did you try flying w/o any box above and below the bad one? That's how I know my 120's a thermal glitch. I haven't tried that, but I did fly with a TKM slide-out loaner and encountered a similar failure. I also put my radio in another plane and the pilot reported that it did not fail during a nearly 3 hour flight. Above my radio is the audio panel, and below it is an ADF. The ADF is inop, so I could remove it... Does the radio require the audio panel to be useable in the airplane? Could I pull out the audio panel and ADF, leave the radio in and plug my headsets into the aircraft (non intercom) jacks and be able to xmit/receive? I'm willing to try anything I can, to avoid throwing good money after bad! It would be one thing if I could explain a set of symptoms to an avionics shop and get an estimate to put this issue to bed, but I can't reproduce the issue at will, unless a tech is willing to go flying with me! :-( Per other post, RG-400 will cure anything, nor do much performance-wise at VHF. I don't completely follow this one??? RG-400 is or isn't necessary, as opposed to RG-58? Thanks for taking the time to respond! Todd |
| Thread Tools | |
| Display Modes | |
| terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 10:39 PM |
| Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 03:37 AM |
| I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 06:39 PM |
| 1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 11:57 PM |
| Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 04:30 AM |
