On Mon, 23 Oct 2006 04:10:17 GMT, Grumman-581
wrote: Roger (K8RI) wrote: As a side note, you could start with about 37K of source code which is what the greeters program ran for the EAA. That compiled into about 7 megs due to the DLLs VB has always been a pig... Hell, even back in the non-Windows days of just compiled MS-BASIC it sucked... It was hidden from you by the fact that the executable was small because it didn't contain everything that got loaded at runtime... You had to have the BASIC runtime loaded also... The more languages I deal with over the years, the more I appreciate straight 'C'... It's clean, it's efficient, it's predictable... And they finally gave us the ability to turn the type checking on. :-)) Originally it just assumed the programmer knew what they were doing and let you do it what ever it was. Lordy...pointers with dynamic memory, dynamic arrays, linked lists, circular linked lists and bidirectional linked lists. It gave the programmer a good feel for the two words, new and free. :-)) Oh yah, and memory leaks. Straight C is what I wrote my first compiler in. I was the only one in the class that wrote an input scanner using current and next state arrays. They tell me I was only the third one in the history of the school to do that. :-)) Every one else used logic statements. Compiler wasn't bad but network theory almost did me in. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger (K8RI) wrote:
And they finally gave us the ability to turn the type checking on. :-)) Originally it just assumed the programmer knew what they were doing and let you do it what ever it was. Lordy...pointers with dynamic memory, dynamic arrays, linked lists, circular linked lists and bidirectional linked lists. It gave the programmer a good feel for the two words, new and free. :-)) Oh yah, and memory leaks. Wow, expecting engineers to do it correctly... Radical concept, eh? grin With regards to type checking, well, you just ran 'lint' on your code to give yourself a better feel for it... I liked the level of strictness with regards to type checking in standard 'C'... I hated what Ada required us to do... More often than not, things became a system.address type in Ada for what I was having to do... You can be object oriented in standard 'C', it just takes the right frame of mind... While I was working on a NASA contract for the MCC and SSCC, we utilized this technique. Here's a write-up that I did on it awhile back describing it: http://grumman581.googlepages.com/object-oriented-c We had a lot of different groups each working on different portions of the entire system and these would be linked at a later date and expected to work together. Collisions at link time were not acceptable. |
On Mon, 23 Oct 2006 22:39:00 GMT, Grumman-581
wrote: Roger (K8RI) wrote: And they finally gave us the ability to turn the type checking on. :-)) Originally it just assumed the programmer knew what they were doing and let you do it what ever it was. Lordy...pointers with dynamic memory, dynamic arrays, linked lists, circular linked lists and bidirectional linked lists. It gave the programmer a good feel for the two words, new and free. :-)) Oh yah, and memory leaks. Wow, expecting engineers to do it correctly... Radical concept, eh? grin Radical huh? :-)) With regards to type checking, well, you just ran 'lint' on your code to This was before ANSI C and lint. give yourself a better feel for it... I liked the level of strictness with regards to type checking in standard 'C'... I hated what Ada The original C didn't have any type checking. You could add, or combine anything with anything regardless of type be it an address, integer, floating point, pointer, array, string, ordinal value, what ever. It added a new dimension to debugging:-)) Never have worked with Ada. required us to do... More often than not, things became a system.address type in Ada for what I was having to do... You can be object oriented in standard 'C', it just takes the right frame of mind... While I was working on a NASA contract for the MCC and "Object Oriented" is really a programming concept although we tend to think of specific languages such as Delphi and C++ as being Object Oriented. If the programmer properly organizes the language he is using he can create the same inheritance and relationships in most languages although being able to define a variable as local or global makes it a tad easier. Of course global makes it easier to defeat the whole concept too. SSCC, we utilized this technique. Here's a write-up that I did on it awhile back describing it: http://grumman581.googlepages.com/object-oriented-c We had a lot of different groups each working on different portions of the entire system and these would be linked at a later date and expected to work together. Collisions at link time were not acceptable. You mean something like a number of modules/routines using the same variable name defined locally and then some one assigns it global? Or assigning a value to an address that some one else uses for something else.? I don't know how many times I accidentally assigned global or local wrongly. I haven't done any programming in C or even C++ in a long time. (I've been retired 10 years now) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger (K8RI) wrote:
This was before ANSI C and lint. I've had more than my share of pre-ANSI compilers... It seems that nearly every project that I work on, at least one of the machines not only does not have a C++ compiler for it, it doesn't have one that is POSIX or ANSI compliant either... As such, you program for the greatest common denominator -- standard 'C' -- so that you can have a single piece of source code that compiles across all platforms... The original C didn't have any type checking. You could add, or combine anything with anything regardless of type be it an address, integer, floating point, pointer, array, string, ordinal value, what ever. It added a new dimension to debugging:-)) But it *built character*... Just look at the quality of developers that you see these days and it will readily become apparent to you that we have a *lot* more character than they do... Never have worked with Ada. You're not missing much... A language designed my committee -- and it shows... "Object Oriented" is really a programming concept although we tend to think of specific languages such as Delphi and C++ as being Object Oriented. Yeah, as I've always said, you can write crap code in *any* language... If the programmer properly organizes the language he is using he can create the same inheritance and relationships in most languages although being able to define a variable as local or global makes it a tad easier. Of course global makes it easier to defeat the whole concept too. Agreed... Allowing the concept of scoping is a quite useful feature in a language... More often than not though, most code that I've reviewed on projects believe in basically two levels of scoping -- at the global level and at the function level... Occasionally, you will see a developer declare a variable in a local block of code, but it doesn't seem to happen that often, primarily in some sort of loop counter or accumulator... From a documentation standpoint though, it looks better if the variables are defined at the beginning of the functions... Code should be readable and documentation should be inline so that you can remember *why* you were doing something a particular way when you have to come back in a couple of years and modify the code... I like to think that you should document the code as if you were going to be having it published in a major publication and subject to peer review... I don't see that happening with the developers who utilize the MS Visual C++ (or whatever) type of products... They draw their user interfaces and plug in the callback actions and about the only comments that you get are whatever the MS development environment automatically includes in the code... You mean something like a number of modules/routines using the same variable name defined locally and then some one assigns it global? Or assigning a value to an address that some one else uses for something else.? I don't know how many times I accidentally assigned global or local wrongly. I haven't done any programming in C or even C++ in a long time. (I've been retired 10 years now) When you are developing a library, you usually have some sort of stub executable that links in the library for testing during the initial development... Let's say that you decide to use a variable 'x' in your library and it needs to be declared by the main module... Let's say that another library is also expecting a variable 'x'... If the library routines are not expecting the variable to be modified by another library routine, there could be issues here... If the first library instead uses 'AAA_x' and the second library uses 'BBB_x', you've prevented a collision at link time... Requiring the user of your library to declare variables is just a core dump waiting to happen though... It's better style if you have your header file for your library do the declaring and have it look to see if something is defined before either declaring the variable or giving a extern reference to the variable... For example: --- USER MODULE --- #define DECLARE_VARS #include "MYOBJ.h" #undef DECLARE_VARS --- USER MODULE --- --- MYOBJ.h --- #ifdef DECLARE_VARS int MYOBJ_x; int MYOBJ_y; #else extern int MYOBJ_x; extern int MYOBJ_y; #endif --- MYOBJ.h --- On the other hand, if a variable is supposed to be only global to the modules in your library and not visible to someone linking your module to their code, you should declare the variable with a storage class of 'static' to minimize the chance that someone could screw something up... It all boils down to proper programming style... If you want to write good code in 'C', you can... If you want to write crap code in C++, you also can... |
Grumman-581 wrote: Roger (K8RI) wrote: This was before ANSI C and lint. I've had more than my share of pre-ANSI compilers... It seems that nearly every project that I work on, at least one of the machines not only does not have a C++ compiler for it, it doesn't have one that is POSIX or ANSI compliant either... As such, you program for the greatest common denominator -- standard 'C' -- so that you can have a single piece of source code that compiles across all platforms... The original C didn't have any type checking. You could add, or combine anything with anything regardless of type be it an address, integer, floating point, pointer, array, string, ordinal value, what ever. It added a new dimension to debugging:-)) But it *built character*... Just look at the quality of developers that you see these days and it will readily become apparent to you that we have a *lot* more character than they do... Yeah. Most of them don't know which end of a soldering iron to pick up, and wouldn't know what to do with a logic analyzer if you turned it on for them and stuck their nose in the instruction book. |
| Thread Tools | |
| Display Modes | |
| Glass Panel construction DVD | [email protected] | Home Built | 0 | July 20th 06 06:41 AM |
| Glass panel upgrade to a Turbo Arrow? | Tauno Voipio | Owning | 9 | March 12th 06 05:29 AM |
| A Glass Panel for my old airplane? | Brenor Brophy | Owning | 8 | July 25th 05 08:36 AM |
| Glass Panel Scan? | G Farris | Instrument Flight Rules | 6 | October 13th 04 05:14 AM |
| C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 04:52 PM |
