I recently purchased an LS7. On days when I eat only a light
breakfast, I'm awfully close to the lower limit of 165lbs for weight and balance purposes. There is a vertical post way forward near the nose that is set up to accommodate a stack of 2.5kg / 6lb ballast/trim blocks, but these unfortunately did not come with the ship. Does anyone know of a source for these? Thanks, Jordan |
![]() Quote:
In the event you can't find ballast/trim blocks I would suggest A BIGGER BREAKFAST. Try some pancakes, toast, biscuits, jelly, butter. Chow down man, this is America, home of the Whopper. Get with the program. Walt |
On Jul 1, 4:25*am, WrongWay wrote:
I recently purchased an LS7. *On days when I eat only a light breakfast, I'm awfully close to the lower limit of 165lbs for weight and balance purposes. There is a vertical post way forward near the nose that is set up to accommodate a stack of 2.5kg / 6lb ballast/trim blocks, but these unfortunately did not come with the ship. *Does anyone know of a source for these? Thanks, Jordan This sounds like the same set up in our LS4. Is there an LS4 nearby? Try a test fit. Ours came with 3 blocks that stack on the single post. The bottom block is shaped to fit the fuselage curves. You could find some old tire weights to melt down, form a mold that fits and make one. Be sure to mark the weight and make an annotation somewhere of the custom ballast weight and CG effects. T |
I recently purchased an LS7. *On days when I eat only a light breakfast, I'm awfully close to the lower limit of 165lbs for weight and balance purposes. There is a vertical post way forward near the nose that is set up to accommodate a stack of 2.5kg / 6lb ballast/trim blocks, but these unfortunately did not come with the ship. *Does anyone know of a source for these? Thanks, Jordan I've been flying an LS-7WL for a few weeks now, I am also right at the lower limit also, in fact I have to wear a chute just to get there. This CG loading gives superior climb performance. I flew almost 5 hours in the mountains yesterday for my first XC flight in this hip, it is absolutely fantastic. Brad |
On Jul 2, 9:50*am, Brad wrote:
On Jul 1, 4:25*am, WrongWay wrote: I recently purchased an LS7. *On days when I eat only a light breakfast, I'm awfully close to the lower limit of 165lbs for weight and balance purposes. There is a vertical post way forward near the nose that is set up to accommodate a stack of 2.5kg / 6lb ballast/trim blocks, but these unfortunately did not come with the ship. *Does anyone know of a source for these? Thanks, Jordan I've been flying an LS-7WL for a few weeks now, I am also right at the lower limit also, in fact I have to wear a chute just to get there. This CG loading gives superior climb performance. I flew almost 5 hours in the mountains yesterday for my first XC flight in this hip, it is absolutely fantastic. Brad A good local hardware store or plumbing supply house should stock lead sheet. I purchased a roll of 1/8" thick sheet and used snips to cut the sheet to match a cardboard template. Sheets can be stacked on the post and held in place with the nut. I ended up using double stick carpet tape to keep them lined up. Much easier and safer than melting lead. Best regards, Craig |
Weight and balance, ballast, trim when flying alone | Mxsmanic | Piloting | 158 | January 20th 08 10:33 PM |
How much do you trim? | Mxsmanic | Piloting | 89 | October 13th 06 05:14 AM |
Electric Trim | Jon Woellhaf | Piloting | 3 | October 4th 05 02:31 PM |
LS4 trim | bagmaker | Soaring | 1 | September 10th 05 03:00 PM |
trim tab help | Robert Loer | Home Built | 0 | March 29th 04 08:30 AM |
