#11
The reason i am installing fender is to minimise amount of debris.
Thought mudguard is appropriate word, sorry, i am not native english speaker. |
On Wed, 15 Jan 2020 10:49:37 -0800, Martynas Bykovas wrote:
The reason i am installing fender is to minimise amount of debris. Thought mudguard is appropriate word, sorry, i am not native english speaker. 'fender; has a lot of meanings including a rope mat put between a boat and a dock to avoid damage to the boat, the skirt-like thing on the front of a railway locomotive and, mainly by Americans, the thin shaped sheet metal or plastic part used to prevent a wheel from spraying water, mud or gravel onto the rest of the vehicle. The rest of the english speaking world calls the last item a mudguard, so call it whatever suits you best. -- Martin | martin at Gregorie | gregorie dot org |
When I was growing up we called that thing a "cow catcher".
No worries about not being a native English speaker.Â* We understood. On 1/15/2020 1:43 PM, Martin Gregorie wrote: the skirt-like thing on the front of a railway locomotive -- Dan, 5J |
On Wed, 15 Jan 2020 15:59:17 -0700, Dan Marotta wrote:
When I was growing up we called that thing a "cow catcher". So did we in NZ. The use of 'fender' for a cow-catcher as something I found in a dictionary. I also knew of 'fender' as a nautical term for both the rope mat thing used between two ships of ship and wharf and for horizontal chunks of wood mounted on piers and wharfs. -- Martin | martin at Gregorie | gregorie dot org |
Most vessel fenders are inflated plastic balls or cylinders with a line attached.
Rope mats are rarely used any more, even on tug boats. Tugs generally have large used aircraft tires as fenders, or sometimes closely folded flaps of sheet rubber, attached around the bow, from one side to the other, like a giant piece of terrible tasting ribbon candy. Regards, Chris Navy test range auxiliary vessel "Swiss Ladder-120 |
Old tires (tyres) work as boat fenders, too. ;-)
On 1/15/2020 4:08 PM, Martin Gregorie wrote: On Wed, 15 Jan 2020 15:59:17 -0700, Dan Marotta wrote: When I was growing up we called that thing a "cow catcher". So did we in NZ. The use of 'fender' for a cow-catcher as something I found in a dictionary. I also knew of 'fender' as a nautical term for both the rope mat thing used between two ships of ship and wharf and for horizontal chunks of wood mounted on piers and wharfs. -- Dan, 5J |
On Thu, 16 Jan 2020 10:37:09 -0700, Dan Marotta wrote:
Old tires (tyres) work as boat fenders, too. ;-) Yep, been there, done that. Using aircraft tyres is a new one for me, though. -- Martin | martin at Gregorie | gregorie dot org |
| Thread Tools | |
| Display Modes | |
| WTB - used Cleveland 40-78B main wheel | Roy B. | Soaring | 1 | February 19th 18 09:25 PM |
| Ventus 2C main wheel inner tube. Short stem or long stem valve ? | [email protected] | Soaring | 1 | July 1st 14 07:07 AM |
| ASW-24 Main Wheel Removal | Lauren Rezac | Soaring | 5 | March 19th 12 05:20 PM |
| Glider Main Wheel Dolly | Jim[_18_] | Soaring | 0 | March 9th 11 05:19 PM |
| main wheel dollies, plans? | [email protected] | Soaring | 1 | July 18th 07 07:55 AM |
