#11
CFLav8r wrote: I recently showed my instructor an ad for a Glasair and he remarked that you could never get it IFR certified with the FAA. He's correct, but only because the FAA does not certify any aircraft for IFR. If you installed adequate avionics and instruments and got a shop to sign off the altimeter, you could fly instruments in the Wright Flyer as far as the FAA is concerned. George Patterson Love, n.: A form of temporary insanity afflicting the young. It is curable either by marriage or by removal of the afflicted from the circumstances under which he incurred the condition. It is sometimes fatal, but more often to the physician than to the patient. |
Ron Wanttaja wrote: As several other folks have pointed out, there is no such thing as "IFR Certified"...if any aircraft is equipped in accordance to CFR 91.205(d) and receives the required regular equipment checks, it can legally be used to fly IFR. Not always the case. The B-24 I was flying is licensed Experimental/Exhibition. It states in the "Operating Limitations" (which appears to be a generic document) that it will be operated VFR only. That being said we did fly it IFR quite often. G I can't find it now, but there was other statements which allowed us to operate IFR. We also carried passengers for hire in the airplane, but that was specifically restricted to Day/VMC. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
"Stealth Pilot" wrote in message ... On Sat, 07 Feb 2004 03:24:11 GMT, "CFLav8r" wrote: Is it true that an experimental aircraft can not be instrument certified by the FAA? David (KORL) since the australian rules are a transplant of the american an aussie answer may be valid. experimental amateur built aircraft are by default signed off for day vfr. IFR requirements are another set of regulations. If the aircraft meets the requirements of those regulations then the signoff can be amended to incorporate the necessary endorsements for IFR. havent seen ifr in person but I have mediated for an experimental Thorp T18 being endorsed for night vfr in this country. was easy. Stealth Pilot Australia The UK equivalent of experimental is the "permit to fly". They are limited to VFR only. |
Ron Wanttaja wrote: As several other folks have pointed out, there is no such thing as "IFR Certified"...if any aircraft is equipped in accordance to CFR 91.205(d) But a Diamond DA-20 can be equipped (probably even comes) with all the necessary IFR equipment, but you can't actually fly it IFR because they didn't embed the metal mesh in the composite skin like they did in the DA-40. -- Ben Jackson http://www.ben.com/ |
"S Green" wrote in
: The UK equivalent of experimental is the "permit to fly". They are limited to VFR only. It appears that you can do so much more in UK with an FAA PPL in an N-reg aircraft than you can with a JAA PPL in a G-reg. Also (from this thread) N- reg experimentals can legally fly over conurbations, at night, and in IMC (which UK PFA types cannot). So, is it possible to build and maintain an N- reg experimental in UK? If not, is it possible to import a US homebuilt and keep it on the N register? TIA, -- Geoff Lane Cornwall, UK |
necessary IFR equipment, but you can't actually fly it IFR because they didn't embed the metal mesh in the composite skin like they did in the DA-40. I'll bite. Why does a metal mesh make a difference? Is it an issue of primary radar returns, or something else? |
In article k.net,
"Geoffrey Barnes" wrote: But a Diamond DA-20 can be equipped (probably even comes) with all the necessary IFR equipment, but you can't actually fly it IFR because they didn't embed the metal mesh in the composite skin like they did in the DA-40. I'll bite. Why does a metal mesh make a difference? Is it an issue of primary radar returns, or something else? Nope -- lightning protection and dissipation. Lightning can literally blow apart nonmetallic structures and home in on the occupants in flight, without tha Faraday cage effect of the metal mesh. |
blow apart nonmetallic structures and home in on the occupants in flight, without tha Faraday cage effect of the metal mesh. Thanks! I never would have thought of that, but it makes sense now that you point it out. |
"Roger Halstead" wrote in message ... On Sat, 07 Feb 2004 22:05:04 GMT, (Ben Jackson) wrote: In article , Ron Wanttaja wrote: As several other folks have pointed out, there is no such thing as "IFR Certified"...if any aircraft is equipped in accordance to CFR 91.205(d) But a Diamond DA-20 can be equipped (probably even comes) with all the necessary IFR equipment, but you can't actually fly it IFR because they didn't embed the metal mesh in the composite skin like they did in the DA-40. I'd seriously doubt the metal mesh would keep it from being certified for IFR. The Beech Starship didn't have a metal mesh and it was certified for IFR. Believe it. The mesh provides the lightning protection required to meet the current Part 23 rules. Starship is one of the reasons the HIRF and lightning standards have increased by several orders of magnitude over the last 10 years. I know guys who worked the Starship's avionics. It was a headache then to meet the old specs. No way it could be certificated today without the extra shielding. The key words in whether you can fly IFR are OPERATING LIMITATIONS. If your operating limitations say "VFR only" you can't fly IFR even if you have the equipment in 14 CFR 91.205(d). If it doesn't say you can't, or it says you can; then you can fly IFR if you meet all the other requirements in Part 91. All aircraft have operating limitations. An experimental gets them as part of the airworthiness certificate. These are pretty loose since it doesn't have to meet any of the 14 CFR Part 23 requirements. A certificated aircraft gets its operating limitations as part of its type certificate. If it can't meet 14 CFR 23.1309 (b), it will be limited to VFR. While it doesn't say anything about lightning, section 23.1309 (b)(4)(i) refers to "...including malfunctions and damage from external sources;" Lightning and HIRF are external sources that must be addressed by the applicant. Gerry |
| Thread Tools | |
| Display Modes | |
| Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 03:41 AM |
| Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 03:16 PM |
| Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 06:54 PM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| Enlisted pilots | John Randolph | Naval Aviation | 41 | July 21st 03 03:11 PM |
