Experimental Instrument Rated?
Old February 7th 04, 03:24 AM
CFLav8r
Default Experimental Instrument Rated?
Is it true that an experimental aircraft can not be instrument certified by
the FAA?
David (KORL)
Old February 7th 04, 04:07 AM
G.R. Patterson III
the FAA?
Many experimental aircraft can be flown under an instrument flight plan when
properly equipped.
George Patterson
Love, n.: A form of temporary insanity afflicting the young. It is curable
either by marriage or by removal of the afflicted from the circumstances
under which he incurred the condition. It is sometimes fatal, but more
often to the physician than to the patient.
Old February 7th 04, 04:31 AM
Roy Smith
"G.R. Patterson III" wrote:
the FAA?
properly equipped.
New jets undergoing initial certification flights are experimental
aircraft. I assume they operate under IFR.
There was a NOVA a bunch of years back on the development of the 777.
It looked kind of wierd to see an airliner with the same "EXPERIMENTAL"
sticker pasted over the door that would you see on a contraption some
guy built in his garage.
Old February 7th 04, 05:00 AM
Roger Halstead
On Sat, 07 Feb 2004 03:24:11 GMT, "CFLav8r"
the FAA?
If it is there are a lot of them out there flying IFR illegally.
(unless I'm missing something in your phrasing)
www.rogerhalstead.com
David (KORL)
Old February 7th 04, 12:42 PM
CFLav8r
by
the FAA?
My question is about the aircraft not the ability to fly it in IFR
conditions.
I recently showed my instructor an ad for a Glasair and he remarked that
you could never get it IFR certified with the FAA.
That didn't make much sense to me, but then again I am the student and he
is the instructor.
The way I figure it, if it is IFR equipped then why couldn't it be IFR
certified?
David
Old February 7th 04, 01:29 PM
Stealth Pilot
the FAA?
David (KORL)
since the australian rules are a transplant of the american an aussie
answer may be valid.
experimental amateur built aircraft are by default signed off for day
vfr.
IFR requirements are another set of regulations.
If the aircraft meets the requirements of those regulations then the
signoff can be amended to incorporate the necessary endorsements for
IFR.
havent seen ifr in person but I have mediated for an experimental
Thorp T18 being endorsed for night vfr in this country. was easy.
Stealth Pilot
Australia
Old February 7th 04, 01:50 PM
JFLEISC
certified?
I'm a little confused here. I didn't think anything on an experimental aircraft
was 'certified'. If it was then it wouldn't be 'experimental'. Experimentals
are not 'certified' to "fly" but they legally do. I believe the rules read
something like "it can be flown under conditions that it is properly equiped
for" i.e. you can't make a VOR approach if it is not equipped with a VOR
receiver. Something like that.
Old February 7th 04, 01:52 PM
Dan Luke
remarked that you could never get it IFR certified with
the FAA.
the student and he is the instructor.
Your instructor is F. O. S.
Dan
C172RG at BFM
(remove pants to reply by email)
Old February 7th 04, 02:36 PM
Dave
Yah... as I understand it, experimental certified aircraft can do
everything a normal/utility certified aircraft can do except:
carry people for hire.
Check out the EAA site for more details...
Dave
the FAA.
Old February 7th 04, 04:20 PM
On Sat, 07 Feb 2004 12:42:27 GMT, "CFLav8r"
conditions.
There are a lot of homebuilt aircraft designs that can't pass the CFR Part
23 requirements necessary to receive a type certificate. Typically, a
design does not meet the stability requirements. Hence, a given design
cannot receive an airworthiness certificate in the normal, utility,
aerobatic, or transport categories. It doesn't make them harder to fly,
but their lower stability does make them less-suitable as IFR platforms.
As several other folks have pointed out, there is no such thing as "IFR
Certified"...if any aircraft is equipped in accordance to CFR 91.205(d) and
receives the required regular equipment checks, it can legally be used to
fly IFR. But unless it meets the requirements of CFR Part 23, it cannot
receive anything other than an "Experimental" certification, and certain
restrictions apply in the form of the operating limitations assigned by the
FAA.
There are probably thousands of Experimental aircraft whose operating
limitations specifically permit IFR operations.
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
Enlisted pilots John Randolph Naval Aviation 41 July 21st 03 02:11 PM
