Logging Right Seat Time
Old May 21st 05, 04:16 PM
CloudyIFR
Default Logging Right Seat Time
I'm a Part 135 pilot and we're starting to get a lot of missions that
are two pilot crews. These are in airplanes that don't require a SIC
as the AutoPilots work, we're not flying over 8 hours and it's not
required by the Type certificate.
I'm a Captain in all the planes but move to the right seat often. When
I'm in the right seat what can I log? From my reading of the FAR's I
can only log Total Time. Is that correct? I can't log PIC as I'm not
the PIC nor sole manipulator of the controls. Can I log landings,
Instrument, X/C, etc..?
If you have a reference I'd appreciate it.
Thanks for the help.
Curt
Old May 21st 05, 04:55 PM
Jose
IMHO, If you are the Pilot In Command, you log PIC time, no matter what
(physical) seat you sit in. (Some planes don't even have a left seat!).
If you are =metaphorically= "sitting in the right seat" (i.e. you are
just along for the ride while somebody else takes responsibility for the
flight) then you don't log anything, no matter what physical seat you
occupy.
That is, you can log anything you want, but you can't use that
particular time towards ratings and currency.
My strict reading of 61.51(e) says that if you are not the "sole
manipulator", then even if you =are= the PIC, then so long as anybody
else is handling the controls, you can't log PIC time, but if you hand
over the controls to the autopilot and take a nap, you can log it
yourself. However, I would maintain that if somebody else is handling
the controls for you, under your direction, then you are merely using an
organic autopilot.
I don't see the essential difference between the two, especially with
the sophistication of some modern autopilots. The FAA may disagree, I'd
like to hear their reasoning (and the reasoning of anyone else who
disagrees)
Jose
I used to make money in the stock market, now I make money in the basement.
Old May 21st 05, 05:32 PM
Mike Rapoport
"CloudyIFR" wrote in message
Curt
I'm not a FAR expert but you should be able to log time where you are the
sole manipulator of the controls. I doubt that two pilots can log time if
only one is required. which I suspect is your real question. It is a good
question!
Mike
MU-2
Old May 21st 05, 06:07 PM
CloudyIFR
I realize I have a job and am getting paid, that's first and foremost,
but it seems that I should be able to log something as I'm doing the
same thing as I would when I fly SIC in the Learjet, but with the
Learjet I get to legally log SIC, whereas in say a Cessna 421 I don't.
Doesn't make sense to me.
Must be something that I can log?
Curtis
Old May 21st 05, 07:22 PM
Paul Lynch
You need to provide more information. What kind of airplane? What is the
seat configuration (# pax)? IFR or VFR operations? What does your company
operations specification require?
Here is the bottom line... If your OPSPEC or the AFM or Part 135 requires a
second pilot you can log SIC. You can only log approaches, landings, and
instrument time where you have your hands on the controls. IF, AND ONLY IF,
one of the above requires a SIC, and you are the designated Captain, you can
log PIC no matter what seat you are in or if you touch the controls. As
above, to log approaches, landings or instrument time you must be operating
the controls.
The reference is contained in Part 135 and 61.
One additional question... Who does your 135 training and checkrides? The
appear to be lacking.
Curt
Old May 22nd 05, 12:13 AM
Howard Nelson
Curtis
Put a hood on the PIC and then log time as SIC (safety pilot)!
Howard
Old May 22nd 05, 12:22 AM
Mike Rapoport
Curtis
I don't see the problem. A 421 is a single pilot airplane, so the (one)
pilot that is flying can log the time. A Learjet is a two pilot airplane so
the two pilots flying it can log time. It makes as much sense for three
pilots to log time in the Lear as two in the 421.
Mike
MU-2
Old May 22nd 05, 02:54 AM
Ron Natalie
Where you sit is not important. However, the rules don't say "LOG PIC
TIME WHEN YOU ARE PIC." In order to do that there are additional
qualifications. The most commonly used one is that the regulations
(lets say Part 135) require more than one pilot.
else is handling the controls, you can't log PIC time,Y
You better read 61.51 again. There are three more clauses than the
one you're reading.
Old May 22nd 05, 03:32 AM
Jose
My strict reading of 61.51(e) says that if you are not the "sole manipulator", then even if you =are= the PIC, then so long as anybody else is handling the controls, you can't log PIC time,Y
one you're reading.
I didn't think they were relevant to the discussion.
Rec, private, or comm pilot may log PIC if...
sole manipulator (& rated) ... or sole occupant ... or (not except for
rec pilots) =is= PIC when two pilots are required.
The other clauses pertain to ATPs, authorized instructors, and student
pilots. So I was focusing on the first set.
We were discussing a situation where only one pilot is required, and
there is another occupant of the aircraft. In this case, I believe that
as I wrote above, a strict reading says that even if you =are= the
actual Pilot In Command (perhaps by dint of being the only pilot aboard,
perhaps by another dint), then if anybody else is handling the controls,
you can't log PIC time. However, if an FAA approved robot is handling
the controls, then you can.
Handling the robot (turning on the autopilot) apparantly counts as
handling a control. You can program the FMS to do the takeoff, cruise,
and landing, take a nap, and set an alarm for when your wheels touch the
ground again, and log the whole thing as PIC. You can do this with a
non-FAA approved robot too, if you are flying an experimental class
aircraft. (At least I think that's true - how much does the FAA get
involved in certification of instrumentation and such for
experimentals?) It's unclear as to whether you can let a monkey operate
the controls and still log it as PIC (which may be a problem for those
that employ the cat-dog-duck method of IFR flight), but if you let a
human act as your autopilot, a strict reading of the rules says nix on
the logbook.
So, you (a regular private pilot) go up in a 172 with a friend who is
not a pilot, you let him take the controls while you very carefully
supervise her, and you can't log the time PIC. The next day you fly a
Cirrus by programming the CID (Cirrus Autoflight Device) and pushing the
GO button, essentially become a passenger while the glass cockpit does
the work, and all that time goes in your book as PIC.
Doesn't make sense to me. This is why I mention the organic autopilot.
Jose
Old May 22nd 05, 04:07 AM
Mike Rapoport
"Jose" wrote in message
news
one you're reading.
sole manipulator (& rated) ... or sole occupant ... or (not except for rec
We were discussing a situation where only one pilot is required, and there
is another occupant of the aircraft. In this case, I believe that as I
wrote above, a strict reading says that even if you =are= the actual Pilot
In Command (perhaps by dint of being the only pilot aboard, perhaps by
another dint), then if anybody else is handling the controls, you can't
log PIC time. However, if an FAA approved robot is handling the controls,
then you can.
involved in certification of instrumentation and such for experimentals?)
It's unclear as to whether you can let a monkey operate the controls and
still log it as PIC (which may be a problem for those that employ the
cat-dog-duck method of IFR flight), but if you let a human act as your
autopilot, a strict reading of the rules says nix on the logbook.
So, you (a regular private pilot) go up in a 172 with a friend who is not
a pilot, you let him take the controls while you very carefully supervise
her, and you can't log the time PIC. The next day you fly a Cirrus by
programming the CID (Cirrus Autoflight Device) and pushing the GO button,
essentially become a passenger while the glass cockpit does the work, and
Jose
basement.
I think that it is simpler. You can log pilot time when the FAA requires
you to be in the airplane performing as pilot. If you are not required (ie
you are one of 4 pilots in a 172) you can't log the time.
If you go through the specific rules this seems to hold true. Every time
that there is an instance where two pilots can log time, it is becasue two
pilots are required by regulation.
Mike
MU-2
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 08:04 PM
Cross Country Logging time Jim Piloting 14 April 21st 04 10:58 PM
Logging time as safety pilot? CFLav8r Piloting 26 February 8th 04 12:35 AM
Where are the CFIG's? Michael Soaring 10 August 19th 03 01:23 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 05:12 PM
